Drivers side headlight
Old Nov 3, 2011 | 12:41 AM
Nevada Smith's Avatar
Nevada Smith
Cruising
Default Drivers side headlight
Bought another Corvette (1996) to hopefully turn real quick. Have a little problem when I turn off the headlights. The right one rotates to the closed position ok but the driver's side rotates closed, then goes back on about 1/3 then off again then open 1/3 about 4 or 5 times before staying completely closed. I looked at the rod between the open and shut and the track open and close; it looks like they might be bent a little. I can't find those parts anywhere. Anybody know where I can get these or am I on the wrong page with this. Any ideas would be greatly appreciated!!
Old Nov 3, 2011 | 06:32 PM
whitenow's Avatar
whitenow
Default Check the bushings first
These are a high failure item, and when they go, the headlights usually move after reaching what should be their stopping point.
Use the search function to find threads on replacement.
Old Nov 4, 2011 | 05:40 PM
STL94LT1's Avatar
STL94LT1
Do a search on headlight bushings.
To Drivers side headlight
