shifter knob removal
Old Nov 8, 2011 | 02:21 PM
Cavi's Avatar
Cavi
Default shifter **** removal
This is probably vey easy but before I do something dumb, how does the shifter **** come off the manual transmission car? Is it just threaded, or is there a pin locking it or something? also, the little plastic insert with the shift pattern, it is just loose on top, and it looks like there should be something under it so it does not titer toter....
Old Nov 8, 2011 | 03:29 PM
Goldcylon's Avatar
Goldcylon
Once you pry up the shifting pattern inset. There is a wedge key that locks the **** into place. You need to pull it out. Then unscrew the ****
Old Nov 8, 2011 | 04:22 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Instructions (with pictures) here:
http://forums.corvetteforum.com/c4-t...b-removal.html
Old Nov 8, 2011 | 05:09 PM
Cavi's Avatar
Cavi
thanks
To shifter knob removal
