Snow Question
Old Nov 10, 2011 | 10:17 AM
AstroMan1's Avatar
AstroMan1
Default Snow Question
How much snow can you drive in without tearing the mufflers off. I'm worried about after it snows and gets ice on top of the snow. I may need to drive the Vette some this winter, my daily driver is giving me trouble. Thanks
Old Nov 10, 2011 | 10:29 AM
Zogs2011's Avatar
Zogs2011
Don't worry unless your mufflers aren't installed correctly you will get stuck a long time before they fall off.
Old Nov 10, 2011 | 11:22 AM
motor city dave's Avatar
motor city dave
St. Jude Donor '16
Old Nov 10, 2011 | 11:47 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Contact Sweet 90. He knows everything about snow weather.
Old Nov 10, 2011 | 12:19 PM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Use public transportation, or walk, it'll be quicker.
Old Nov 10, 2011 | 03:53 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
after about 4 inches you start to plow with the lower air dam.
Old Nov 10, 2011 | 04:01 PM
nutz4c4's Avatar
nutz4c4
Old Nov 10, 2011 | 04:10 PM
RedLS1GTO's Avatar
RedLS1GTO
Drove my 87 through many Chicago/Northern Indiana winters and lots of snow.
Not much worse than any other RWD car and ripping the mufflers off is simply not going to happen (unless of course they are about to come off already).
Old Nov 10, 2011 | 04:38 PM
ToniH's Avatar
ToniH
First thing that happens when there is too much snow is you overheat your engine if you are not carefull. This is what happens: your front airdam works as a snow plow and it directs all snow into your radiator blocking it. If you don't notice this and you really overheat it you might lose a head gasket. Don't ask me how I know all this...
Drove my C4 through 3 Nordic winters. No problem starting it at -35°C (-31°F) though, didn't even have a engine block heater...
Old Nov 10, 2011 | 06:35 PM
GreyGhost's Avatar
GreyGhost
or you drive backwards
Old Nov 10, 2011 | 09:23 PM
George6488's Avatar
George6488
I thought it was illegal to take a Corvette out in bad weather???
Old Nov 10, 2011 | 09:43 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
I'd look at ripping off the mufflers as an excuse to get muffler eliminators.
Old Nov 10, 2011 | 09:50 PM
silverja's Avatar
silverja
Default Should Not be an Issue
I cannot say I drove my C4 in the winter here in Western Pa, but I did drive a C3 for awhile and it was pretty amazing. Of course the C3 had 15 inch wheels and I put on studded snow tires. Passed a jeep going up a snow covered hill once. The guy in the Jeep had a look on his face that was funny. My concern with driving a C4 in the winter has to do with the wide tires, although you could put on 4 snow tires all around for the best control. Sorry - The mufflers should not be an issue, but take note of what previous posts warned - the front air dam in particular.
Best of luck.
Old Nov 11, 2011 | 11:37 AM
C4orce2's Avatar
C4orce2
What the hell is snow? I've only heard about it.
Old Nov 11, 2011 | 11:53 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
If the snow is deep enough to plow with the front air dam then stay home. I drove my 86 one winter when my son's car died and I gave him my daily driver. Here in W Michigan we get a lot of snow but the snow plows usually have it removed within a day or two for severe storms.
Normally the plows can keep up with it so the roads are fairly clear.
Unless you REALLY live out in the boonies you should be able to get around on most winter days by slowing down and giving yourself extra time.
The main problem with winter is that your engine bay gets very dirty from the dirty slop off the road.
Old Nov 11, 2011 | 11:57 AM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Its the white stuff thats in those animated movies Ice Age & Ice Age ll
Old Nov 11, 2011 | 12:19 PM
dukeallen's Avatar
dukeallen
Take the ice from your drink; crush it into a powder; spread it in the floor and walk across it.
For Canadians, it's the white stuff that has something called "ground" hidden under it.
To Snow Question
