Cooland Temp read "LO" on dash
. When I changed it I drained the radiator but forgot that it still had antifreeze in the top of block and got it all over the front of the engine bay. Now the dash temp reads "LO" all of the time and the car didn't run for awhile so I let it dry for a few days. Now it still runs very rough and the "LO" temp is still there.
You can also pull the CTS connector off the CTS and see if you get a DTC 14. If you do, then you know the ECM is seeing a signal and the wiring is ok. If you don't get a DTC 14, you may have a wiring issue. Check for 5v at the sensor connector and also verify the ground.
Regarding the rough running....if you poured coolant all over the front of the engine, you also drenched the Optispark. Rough running is a typical symptom. Sometimes if you run the engine long enough, it'll dry out. Other times, if you remove the cap from the Optispark, you can dry it out / clean it up (including the optical sensor itself) and it'll be fine. Other times you have to replace it.
The CTS on the front of the engine goes to the ECM.
