Battery question
Old Nov 19, 2011 | 12:15 PM
hitmanpty's Avatar
hitmanpty
Default Battery question
I think Iam going to get a new battery today.
My battery cable had been modify. so cable end are not screw any more. use pole now.
what battery spect do I need for my vette (1986)????
also how long will a new battery last with out use. I inted to umplug the battery when not in use.
Old Nov 19, 2011 | 01:39 PM
c4cruiser's Avatar
c4cruiser
You can get replacement battery cable ends that are made for the original style side posts. The top post design can be a problem as the postiive terminal is very close to the firewall brace. Too much movenment and the post can contact the brace. That is not a good thing.
The stock battery is a Group 75 style. If you can find the Interstate Battery brand, get the MT75. If AC-Delco batteries are available, get a 75-6YR battery. Note that both of these batteries are the OEM side terminal type.
A full-charged battery that is not connected can last a long time. If you have access to a 110-120v electrical outlet near the car, use a battery tender to keep the battery at full charge. Two of the best IMHO are:
Deltran and
CTEK
Both are available from Summit Racing and they ship worldwide. You can also get the side terminal cable ends from Summit.
Old Nov 19, 2011 | 02:35 PM
frenchsquared's Avatar
frenchsquared
An optima will last 10 or more years.
I cut a thick piece of rubber and put it between that brace and the top battery post.
With my stereo I have to run an optima. Have one in all my cars. Never had to replace one.
To Battery question
