Another question
Old May 7, 2002 | 10:37 PM
Guest
Guest
Posts: n/a
Default Another question
My dad has a 1993 Corvette with a six speed as i said, It have stock rearend gears. ( if i remember right they were 3.45, or 3.54)I would like to know if he switched to 410 gears,what would happen to his RPM?I know it would go up, but how much? I know it depends somewhat ont the gearing and the tranny he wants to know what would rpm change is at diffrent MPH increments through every gear. And how do you know this also?
I need the answer in about an hour
Old May 7, 2002 | 11:10 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Another question (jdhommert1)
I won't go up much. I used to have a gear selector calculator but I don't. anymore.
Figure it this way. Whatever rpm he is running at a particular speed, add 15% to it and that will basically tell you what he would run with 4.10's.
Old May 7, 2002 | 11:11 PM
Guest
Guest
Posts: n/a
ttt, only 20 minutes until i call my dad. Who has put 410's in there vette? I know there is quite a few people, so how much did your rpm go up?
To Another question
