winter project
Old Nov 30, 2011 | 08:49 PM
comanchepilot's Avatar
comanchepilot
Cruising
Default winter project
Hi,I am asking for advice on my 1995 c-4 corvette.Over the winter i would like to replace1 the opti spark,2 the water pump,3 the spark plug wires.Does any one have recommendations on replacement manufactures?thanks.
Old Nov 30, 2011 | 09:19 PM
kleptopigdog's Avatar
kleptopigdog
msd opti spark & wires
Old Dec 1, 2011 | 11:26 AM
littlesk8cracker's Avatar
littlesk8cracker
definitly not msd. msd optis seem to have about a 50% fail rate, and iv heard nothing but bad reviews on msd wires and my personal set failed after only a few weeks. i used a stock delphi opti which seem to have great reviews. if it lasted that long stock, then why not use it again? and i use taylor plug wires which also get great reviews. the optis not a bad job at all, make sure to read lt1*c4's article on it, has step by step instructions with pictures
Old Dec 1, 2011 | 04:11 PM
sailorsteve's Avatar
sailorsteve
For my money the GM parts don't get enough love. My '92 has the unvented-type Opti, replaced with a new GM unit a few years back because the original had a little bath under the hood. But the original was over 10 years old, and the cap gasket had dried out, didn't take much water to finish it off. When a car gets old, especially if it spends lots of time sitting, the seals, etc. are prone to drying out.
I used Delco plug wires also, they've been fine, and the lengths were perfect, very important on the LT1.
Old Dec 1, 2011 | 05:07 PM
comanchepilot
Cruising
Default water pump
Thank you for the reply,do have a recommendation on a water pump?thanks
Old Dec 1, 2011 | 05:28 PM
popo8's Avatar
popo8
Ive done MSD billet optis.... had it rebuilt and sold it....
Ive done GM optis, last pretty good till you spin the snot out of it....
Currently doing Dynaspark Opti, and although the quality may be hit or miss, the Customer Service is second to none....
Old Dec 1, 2011 | 09:00 PM
kleptopigdog
Default opti
I've had the msd opti on my car for about a year and half w/ no problems .What kind of problems did ya'll have?
Old Dec 1, 2011 | 09:01 PM
popo8's Avatar
popo8
I had a persistent 5100rpm and above misfire.....
Old Dec 3, 2011 | 11:56 AM
littlesk8cracker
i heard alot of problems with the screws constantly loosening up on the msd unit and then the unit fails. as for water pump, i went with a meizere electric pump
Old Dec 3, 2011 | 12:14 PM
comanchepilot
Cruising
thank you,do you have any idea on a none electric water pump,mine has 90k on it.It makes sense to replace it at the same time as i replace the opti spark.
Old Dec 4, 2011 | 12:56 PM
sailorsteve
I used Delco several years ago, no problems.
To winter project
