Door Panels
Old Dec 1, 2011 | 07:24 PM
95VetteMan1's Avatar
95VetteMan1
Default Door Panels
I'm putting on new door panels, but when I install them..they are still loose..any suggestions?
Old Dec 1, 2011 | 07:55 PM
F22's Avatar
F22
If they're loose at the top, it's because the weatherstripping on the door terminates in two huge blocks on top of the door, both front and back. The door panel sits on top of those rubber blocks.
The early C4 door panels had screws to hold the bottom of the door panel, but the late C4's use plastic Xmas tree type connectors that have some play vertically, allowing the rubber blocks on top of the door to push the panel upward out of the door itself (take a careful look, that's how I figured it out).
I cut down the blocks to the minimum needed to hold the weatherstrip in on both ends of the door and now the door panel sits a lot more lower. It's still somewhat elevated, but nothing like it was.
I also added a screw and insert to the structural tab that is about halfway up the back of the door. Drill a hole and put an insert in the tab, then when you put the door panel in, use a wide headed screw and drive it through the door panel (after lining it up with the insert of course). The early C4 door panel had a screw here, but the late C4's don't. I know, we have both an 87' and a 95'. That'll help hold the door panel down on the back side.
Here is a thread I created and hope this helps
http://forums.corvetteforum.com/c4-g...panel-fix.html
Old Dec 1, 2011 | 09:22 PM
kleptopigdog's Avatar
kleptopigdog
Also go to any auto pait post more tommorow lap top out ofpower...Never mind on a charger now .Go to any auto paint supplyer ,the'll have those little white oblong clips [behind the courtesy light,door grab, replace all these .Next do not use the old clips along the bottom ,any chevy house has these .Take an old one w/ you .The chevy house here in town didn't even charge me for 10 of them .
Old Dec 2, 2011 | 08:22 AM
HlhnEast's Avatar
HlhnEast
Whhhaaaa?? You have some "in" with them? Did ya just get a $200 oil change?? Hard for me to fathom something from Chevy for free.
Old Dec 2, 2011 | 01:29 PM
kleptopigdog
every chevy dealership parts dept here wichita has treated me well.
Old Dec 2, 2011 | 02:00 PM
markKlein's Avatar
markKlein
Make sure the windows are down when you put the new panels in, they seat much better that way.
To Door Panels
