hood release cable broke
This what I used, and took it less then 5 minutes to open. Just go slow and steady when you are fishing for the latch.
Good Luck.
I have those cables staring at me now. 2 years they have been in a basket on my desk, along with other stuff I have been putting off dealing with.
Push down on your hood over the latch on the passenger side. If you hear a click it means the hood didn't shut evenly the last time you had it up. If thats so try pulling the latch again. I bet it releases.
Lube always helps prongs go in and out of holes much easier.
- Remove fender
- Get a coat hanger and make a hook
- Introduce your hand thru the space between your fender and wheel well
- Introduce the hook from the wiper area,then catch it with your hand and guide the hook to the latch,till you engage them
- Stand up and pull to the center of the car,that should open your hood
- Now never forget to add emergency cables
ps : i have a bad driver side cable retainer and one day it popped out leaving the cable loose and hood closed (all of this after i had the remove fender experience)
it was a real let down..but i remembered that i had emergency cables !!!!
Wow i was happy,i pulled them and HAPPY HOOD OPEN AGAIN
The hanger has to be hard enough to pull but soft enough for you to acommodate every angle every try,here ya go,this is how i opened mine,the work of your left hand guiding it to the latch is very very important,thats the reason you have to get familiar with the latch's location :
Here you go !
This is what the tool does :
Now you need this :
http://www.mamotorworks.com/corvette?frame=1.8064
Or just do it yourself :
http://forums.corvetteforum.com/c4-g...with-pics.html
Let us know !
I just have to find a please that sells this item so far have not found any store..
I also secured the release cables in place with small wire-ties.
After that happened, I put on emergency pulls before my hood was shut again.
