Air pump
Old Dec 23, 2011 | 04:33 AM
johnnycobra's Avatar
johnnycobra
Default Air pump
I broke my air pump bracket and am wondering what is the consequence of not replacing the air pump. besides just the serpentine belt length
anybody know. ive heard some people have air pump deletes they have made.
Old Dec 23, 2011 | 07:19 AM
rodj's Avatar
rodj
All answered in your other post.
http://forums.corvetteforum.com/c4-g...to-remove.html
If you remove AIR pump you need a idler (unless you remove A/c compressor as well.)
Old Dec 23, 2011 | 09:21 AM
johnnycobra
but will it hurt the engine? I dont understand the purpose of the air pump0 I guess
Old Dec 23, 2011 | 09:26 AM
sailorsteve's Avatar
sailorsteve
You may not pass emissions inspection without it.
Old Dec 23, 2011 | 06:32 PM
93Rubie's Avatar
93Rubie
This will be the only side effect. On start ups especially cold ones, the air pump injects air into the exhuast stream to cut down on hydrocarbon emissions. Unburnt hydrocarbons that is.
Old Dec 24, 2011 | 01:35 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
It will not "hurt" the engine w/o it. You, of course, need to compensate for the belt routing to avoid belt failure -- even if a shorter belt were installed. That's why people are forced to use an idler pulley in place of the air pump. IMO, a replacement USED brace is going to cost less than the adaptation required to run without the air pump.
The air pump adds air to the exhaust stream for two reasons. One is to heat up the catalytic converter(s) faster. By doing this, the converter begins doing it's "cleaning" faster. Also, that extra air helps add enough air to any unburnt engine fumes so they incinerate (burn up) when they go thru your converter.
Some believe the added air only raises the oxygen content in your exhaust -- thereby reducing the PPM for carbons IN RELATION TO THE AMOUNT OF AIR. And, that the extra air doesn't aid in the incineration process.
I've never seen "official" looking tests to confirm the later theory.
Old Dec 25, 2011 | 11:35 AM
johnnycobra
Default Ok I have an idea of what the air pump does thanks to forum folks.
I think ill replace the bracket and start work on an idler, once i get the bracket installed i can do some measurements to get the same layout.
thanks for all the replies guys
Old Dec 26, 2011 | 09:13 PM
HlhnEast's Avatar
HlhnEast
Should be a bunch of brackets out there with everyone doing the elimination. Ive got the whole deal somewhere around here in a bucket that I might be talked into letting go of at a reasonable rate plus shipping. PM me if interested.
Old Dec 27, 2011 | 11:35 AM
johnnycobra
Default I would very much be interested,
let me know what you need and of course ill pay shipping. I appreciate the offer. you're making me a happy man!
Old Dec 27, 2011 | 11:43 AM
johnnycobra
Not required in south carolina
Old Dec 29, 2011 | 01:44 PM
jeffs40thgtp's Avatar
jeffs40thgtp
take it off they suck anyway... that was the first thing to go on my 91, i got a airpump delete form tpis and it looks good
Old Dec 30, 2011 | 09:56 AM
richauto's Avatar
richauto
The air pump also keeps the temp down on the cat converter. I would not remove it. Also make sure there is no exhaust coming through the check valves. They allow air into the exhaust.
Old Jan 1, 2012 | 07:45 PM
johnnycobra
Default really int4rested in a air pump delete
let me know what you need and of course ill pay shipping. I appreciate the offer. You're making me a happy man!
:d
:d
let me know what you need.
To Air pump
