Key Pellet Question
Old Dec 29, 2011 | 04:04 PM
1963SS's Avatar
1963SS
The resistor works just fine on the 95 and 96's. The only difference between them and the 1990 models is that you have to disconnect the resistor each time you start the car. You can't just leave the resistor hooked up. The switch mentioned above works fine.
Old Dec 29, 2011 | 04:11 PM
c92vette's Avatar
c92vette
A couple of point here on the VATS. The pellet resistor circuit can be modified with a resistor of the same value to disable VATS. It will work if done correctly on all models. Second the "Security" light should illuminate when shutting down the vehicle and removing the key. This shows the VATS is resetting itself to arm for the next starting attempt. If you don't see the "Security" light it may be burned out. Is it worth the trouble to tear apart the instrument panel to change the bulb? Not to me but...................
Old Dec 29, 2011 | 04:23 PM
Siveck's Avatar
Siveck
Interesting. That would mean that the key would have to be removed every time the car is shut down. To the OP: Do you leave the key in the switch while the car is in your shop?
Old Dec 29, 2011 | 04:54 PM
gresmi's Avatar
gresmi
My key is rarely pulled. Park in a garage at night, key stays in. I'm in the middle of Kansas where the chances are higher of losing your keys than they are having your car stolen so I usually leave the keys in the car.
Security light on my car does work and I noticed this afternoon that it comes on when I open the door. Once the door is closed it goes off...when I start the car, it's off also.
Interesting note, might not be related and it's only happened once that I'm aware of. I have a manual 6-spd. I was backing out of the driveway, at night, and there was a quick 'flash' of light. I wasn't sure what it was but as I remembered the light I also remembered hearing the door locks cycle to, I think, the unlock position. The flash of light was a very quick cycle of the interior lights. Again, this only happened once...thought it was strange but haven't thought too much about it. As, as I said before, I'm guess its not related.
Greg
Old Dec 29, 2011 | 05:19 PM
Siveck's Avatar
Siveck
Try removing the key momentarily after parking in your garage. Then place it back in the cylinder after a few moments for the next trip. See if the issue persists.
I'd like to hear from some '95-'96 owners as to whether their car will restart without removing the key after shutdown.
Old Dec 29, 2011 | 05:20 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Originally Posted by gresmi
I'm afraid a new cylinder is in my future also. I can completely rotate the cylinder without a key. The car won't start without the key, which is a good thing, but everything else works (radio, heater, fan etc).
Did the new cylinder they installed have the VATS system? If it was up to me, I would rather not have it. Just another electrical gremlin with the potential of making you pull your hair out.
Greg
I hate to tell you, but you are stuck with the vat system, and don't bother to install the by-pass system, when the cylinder goes, it's not going start no matter what you will do, better off bite the bullet, and replace it. I had the by-pass system installed, and the ignition failed I got towed.
I can tell you I never had issue again, but remember you will be getting new set keys.
Good luck.
Old Dec 29, 2011 | 06:48 PM
vettedan's Avatar
vettedan
The only thing the resistor does is let the VATS verify that the correct resistance that is programed into the VATS is pressent. The VATS does the rest. It sends a 50Hz signal to the BCM or ECM thus allows ignition, fuel supply and starter to function.
Old Dec 29, 2011 | 07:37 PM
95tripleblack's Avatar
95tripleblack
OK, I'm game. Went out to car and opened door, security light came on. Started car security light went off. Shut it down and security light came on. Left key in and restarted, no problems. Took key out while it was running and shut it down. Inserted key and it started right up. Took key out and shut it down, cylinder would not turn without key. Inserted key and it started right up.
Did I miss any scenario?
Oops two more, started car, shut down, security light on, left key in and opened door then shut door, security light off, restarted no problems. Turned key off, did not open door, security light flashing waited for it to go out before opening door, got tired of waiting concluded experiment.
ps. when I say security light on, in every instance I meant flashing.
Old Dec 29, 2011 | 08:22 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I had one key that worked and one that stopped working on a 96 Impala SS that I had.
Rather than buying new keys, I did a VATS bypass. I didn't know any better and just tried wiring the right resister permanently into the circuit. I didn't use a relay or anything else.
It worked for at least 10 years before I sold the car.
I don't know if the Corvettes are different or not, but the VATS bypass still sounds like a good idea to me.
Old Dec 30, 2011 | 09:38 AM
Siveck's Avatar
Siveck
It sounds like the '95-'96 VATS is no different than the '86-'94 VATS. With that being the case, the simple fix would be the plug in resistor that can be found in the parts catalogs from supporting vendors.
Old Dec 30, 2011 | 07:56 PM
rodj's Avatar
rodj
Wrong
The CCM equipped cars look for a change of resistance and the correct resistance when key turned.
The early cars only look for the correct resistance which is why the permanent resistor trick works
read
http://www.vatssucks.com/
On CCM cars you either get VATS programmed out
or install a fuel enable signal generator that supplies the correct signal to the ECM/PCM
( you also have to bypass the starter enable relay to fully delete VATS )
Old Dec 30, 2011 | 08:13 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I can guaranty you, the car will restart as many times as needed without having to remove the key.
Example: Pull into a drive in burger place (like Sonic), park and shut off engine without removing key.
When your ready to go, car starts right back up.
Old Dec 30, 2011 | 10:40 PM
  #33
Siveck's Avatar
Siveck
Interesting. It seems that we have conflicting info here. Sources are saying that the '95-'96 system cannot be disabled only by using the resistor. On the other hand, owners are saying that the key can be left in and restarted. I fail to see how leaving the key in is any different than wiring in the resistor. Maybe the slight movement of the key changes the resistance?
Old Jan 4, 2012 | 02:16 AM
  #34
Phat98's Avatar
Phat98
I used the resistor bypass on my '96, no issues - been working great the last 6 months. My wife leaves her keys in her '94 all the time in the garage and has had zero problems.
Old Jan 4, 2012 | 02:23 PM
  #35
gresmi's Avatar
gresmi
OP UPDATE:
Over the last week I have been using my 2nd set of keys on my car with a 'pellet' that is visibly in much better shape. So far the car has started every time. I have also started the car many times after not pulling the key...sometimes only a few minutes had passed between tries. I have been watching for the security light and on my car it's not consistent. Usually when the key is in the ignition and the door is open I'll see a blinking security idiot light...but not always. I have never seen the security light in any other situation as of now.
I'm not yet convinced my problem was or is with my key. I'm hoping it is but time will tell.
Thanks to everyone for all the input and help...if nothing else, I've learned a lot about my 95's VATS system!!
Greg
