Windshield Washer Fluid
Old Dec 28, 2011 | 07:40 AM
Crankpin's Avatar
Crankpin
8th Gear
Default Windshield Washer Fluid
Last year I noticed my windshield washer fluid froze solid. We never got below 0 degrees F. So I figured I would replace it with new fluid. Worried about cracking the resevoir, I bought an Anti-Freeze tester and tested the old and new fluid. Both did not register at all. It was supposed to read -20 degrees F but it did not register even 32 degrees F. My question....Does an Anti Freeze tester work for windshield washer fluid ?
Old Dec 28, 2011 | 09:25 AM
sailorsteve's Avatar
sailorsteve
If you use the kind with colored ***** in it, I would think not, because they work by specific gravity, which would be different with the w/s juice.
Old Dec 28, 2011 | 09:31 AM
Joe C's Avatar
Joe C
i've never heard of that stuff freezing, but i have heard of those quick lube outfits using blue colored water when topping off the reservoir. i wouldn't think an antifreeze tester would work on windshield washer fluid.
Old Dec 28, 2011 | 10:01 AM
KYbaldguysC4's Avatar
KYbaldguysC4
Last winter my son bought a gallon of antifreeze from the dollar store and put it on a shelf in the Garage. My garage is a uninsulated pole barn he went out to get it to hat to his car and it was frozen solid !! what can you say !
Don in KY
Old Dec 29, 2011 | 10:12 AM
sailorsteve
Don in KY
I can say, next time buy from the two dollar store.
"The bitterness of poor quality remains long after the sweetness of low price is gone" - Stanley Marcus. Never heard of him? His partner was a guy named Niemann and they had a little store in Texas...
Old Dec 29, 2011 | 06:09 PM
Steve59's Avatar
Steve59
Windshield washer fluid comes in two types, the Summer mix and the "all weather mix". I always use the "All weather mix" it's good down to, I believe -20*. Don't use anti-freeze in your washer, it will leave a mess on your windshield.
To Windshield Washer Fluid
