Heater problem
Old Dec 28, 2011 | 10:20 AM
Sheprzr's Avatar
Sheprzr
6th Gear
Default Heater problem
Just bought a 1987 vette and allready have a problem.Heater sometimes blows hot air then if i shut engine off sometimes it will only blow cold. Anybody know what would cause it?.Thanks, Sheprzr
Old Dec 28, 2011 | 11:41 AM
95tripleblack's Avatar
95tripleblack
I have the same problem, as do many here. It is most likely the blend door not closing properly, mine flutters and tries to close but does not fully close. I closed mine by removing the relay and pushing the door closed with a long stick. For the exact location and some pictures do a search of heater, blend door etc and there are several posts to help you out.
Old Dec 28, 2011 | 11:38 PM
Sheprzr's Avatar
Sheprzr
6th Gear
Thanks, It seems to me that it could be the part that regulates the temp. control . But I dont know even where it is. I will use your advise and see if I can find something on the internet. Shep
Old Dec 29, 2011 | 02:03 AM
rodj's Avatar
rodj
Man or Elec air ?
Old Dec 29, 2011 | 08:18 AM
red89c4's Avatar
red89c4
mine did the same thing. after repacing the air blend door actuator, the controller and extesive research on this forum i discovered the programmer was the problem. it is under the drivers side dash and hard to get to but worth the effort. any tv/radio repair shop can resolder for less than $10. call me if you need help 770 235 5257.
Old Dec 29, 2011 | 09:29 AM
Sheprzr's Avatar
Sheprzr
6th Gear
Originally Posted by rodj
Man or Elec air ?
The one with cimate control.It dont matter where i set the temp. Still does the same thing.
Old Dec 29, 2011 | 09:30 AM
Sheprzr's Avatar
Sheprzr
6th Gear
Thanks, I think i will call you later today.
Old Dec 30, 2011 | 08:06 AM
red89c4's Avatar
red89c4
Sheprzr
check out these two post, good instructions and pictures.
http://forums.corvetteforum.com/c4-g...d-removal.html
http://forums.corvetteforum.com/c4-g...king-help.html
Old Dec 30, 2011 | 11:47 PM
Cliff Harris's Avatar
Cliff Harris
These symptoms sound like bad solder connections on the HVAC programmer PC board. The HVAC programmer is located right above the accelerator pedal. Two large resistors feed voltage to the temperature door motor. They get very hot and cause the solder connections to go bad. They are shown in this picture (lower left corner -- note heat discoloration on PC board):
The HVAC programmer is held in place by one 7mm screw (tab in lower left corner of the pic). You also need to remove the press on clip buried among the vacuum hoses on the back. I replaced mine with a nut.
To Heater problem
