front suspension problem
Old Dec 28, 2011 | 08:25 PM
yorkfitter's Avatar
yorkfitter
Default front suspension problem
I have an 86 with Z51 suspension that is sagging on the front drivers side, and sitting up on the rear passanger side. I could not see any cracks on the spring while it was on the car. I removed the spring and found a very small gouge, about a pencil lead deap and about 6in long, in the center of the spring. Everyting else looks ok though I can not see under the mounts. Is it possible to mount the spring the opposite way to see if the suspension sags the oppisite way? Is it possible that it is the bushings binding the suspension they are old and cracked. How many shims are supposed to be on the spring, there is one on each mount now, the bood says i could have up to 2 per side. Also does a spring wear out after 25 years?
Very confused any help would be appreciated
Old Dec 28, 2011 | 08:35 PM
oldalaskaman's Avatar
oldalaskaman
yes
Old Dec 28, 2011 | 11:50 PM
slickfx3's Avatar
slickfx3
old bushings could deform, and cause the sagging, check those if too many miles/rot/damage
Old Dec 29, 2011 | 12:39 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
First, you need to determine if it is a front, rear or both problem. Jack both back wheels of the ground. Make sure you put the stands in front of the back wheels on the frame making sure they are exactly equal. Remove the back wheels, and try to make the car as level as you can, front to rear, sitting on the front wheels.. Now check your front height, is it equal side to side? If not, it could be a bad front spring (not uncommon). There is no front adjustment other than shims. If it's level, it's the back spring loading the car. It is adjustable by the bolts on the end, though you could have a bad rear spring. Bad bushings causing your problem is possible, though not likely.
Old Dec 29, 2011 | 03:25 AM
gerardvg's Avatar
gerardvg
Hi yes the composite spring wont last forever, oil and heat will damage it.
When you replace the spring you will have to realize that over time it has slowly lowered your vette. A new spring may have the front of your vette too high Best to put a new rear matching spring in at the same time
I highly recommend coil over shock absorbers, that way you can raise or lower the car to the ride height you want with a few turns
Old Dec 29, 2011 | 10:36 AM
gresmi's Avatar
gresmi
Yorksitter,
Have you checked the bearings and shocks? It sounds like your problem is more severe than the problem I had but my '95 car was 'sagging' in the front. Not a lot but you could tell it was riding lower than what it should be. The adjustable shocks the PO had in my car were leaking so I started with new shocks. Once I had the car on jack stands it was apparent my bearings were bad, maybe up to a 1/4 wobble at TDC of the tire. In the end, I replaced the hubs with new units and went back with basically a stock gas shock. This raised the front end of my car 3/8" (clearance between fender and tire). This doesn't seem like a lot but it has made a big difference on not only the look of the car but it's ability to take dips without turning the front end of the car into a sled.
Keep us updated on what you find. I'm curious to know if your problem is spring related.
Greg
Old Dec 29, 2011 | 01:31 PM
yorkfitter's Avatar
yorkfitter
If I install coil over shocks will that replace the mono leaf? Anyone recommend a coil over shock or a monoleaf.
Old Jan 27, 2012 | 10:01 AM
gresmi's Avatar
gresmi
Yorkfitter, did you end up doing anything to the front end of your car to address the sag??
Greg
To front suspension problem
