Vacuum line location
Old Jan 5, 2012 | 05:34 PM
2001convertable's Avatar
2001convertable
Default Vacuum line location
Hi, I have a vacuum line off and can't for the life of me tell where it goes.Maybe someone can help. The line is coming off a tee against the drivers side wheel well near the master cylinder. I must have knocked it off cleaning the compartment.
Old Jan 5, 2012 | 05:48 PM
aminnich's Avatar
aminnich
On the late model C4s the lines off that T go to the cruise control servo and the one of the top of the T goes down below the battery. No idea on a C5 though.
Old Jan 5, 2012 | 06:01 PM
F22's Avatar
F22
There's a vacuum line diagram on a sticker in every engine compartment. Find that and you'll have your answer.
Old Jan 5, 2012 | 06:03 PM
F22's Avatar
F22
Another method is to take the vacuum line and do a full 'rotation' in all directions. Where the outer circle ends, is where it must go. This works for wires too!
Old Jan 5, 2012 | 06:06 PM
2001convertable
Thanks I will look.
Old Jan 5, 2012 | 08:51 PM
oldalaskaman's Avatar
oldalaskaman
could post in C5, they might actually know
Old Jan 5, 2012 | 09:27 PM
2001convertable
The problem is in my 1987
Old Jan 5, 2012 | 09:34 PM
oldalaskaman
oops, sorry, let me go look at my 87 , be right back
Old Jan 5, 2012 | 09:45 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
And that is why everyone should always list what year car they are seeking help for.
From your user name and avatar, everyone "assumed" you were asking about a C5.
Even in the C4 model run, there were vast differences through the years.
Old Jan 5, 2012 | 09:58 PM
oldalaskaman
the only 't' close to that location on mine , goes to the vacum ball one way, the cruise control and then to the fire wall. there is another that goes from the emmisions mess in the front wheel well , to a t and then to the underside of he tpi, theres a switch there.
Old Jan 6, 2012 | 07:20 AM
Joe C's Avatar
Joe C
- sometimes, even within a particular model year, there are running production changes. i don't know how bad C4's can be, but the all time worse, configuration nightmare is the 1969 corvette.
Old Jan 6, 2012 | 08:18 PM
rosros's Avatar
rosros
I did the same thing on a C4, had a local mechanic smoke the engine to find the other end. I had a 't' by the left fender. That line went into the harnass next to the battery...never would have found it without the smoke.
To Vacuum line location
