PKE Remote
Old Jan 11, 2012 | 10:01 AM
chuckhinva's Avatar
chuckhinva
4th Gear
Default PKE Remote
PKE on my '96 does not work. The light does not come on when I turn on the ignition and I can't get it to respond when I try to program it. The remote key fob does not work either (will not turn PKE off/on or open the doors or hatch). Any thoughts?
Also I undertand these things are hard to find.
Old Jan 11, 2012 | 10:31 AM
Goldcylon's Avatar
Goldcylon
Have you replaced the battery in the fob?
Old Jan 11, 2012 | 12:02 PM
markKlein's Avatar
markKlein
We can probably tell you what is wrong if give us enough detail. Exactly what did you do to try and program it (each step), and what exactly happened at each step?
The fobs are easy to find, just hard to find for less than about $130. Before you go looking for a new fob let's see if we can do some diagnostics.
Old Jan 11, 2012 | 12:19 PM
markKlein's Avatar
markKlein
Also, check fuses 26, 40 and 42.
Old Jan 13, 2012 | 09:39 AM
markKlein's Avatar
markKlein
chuckhinva, got an update on this?
To PKE Remote
