1984 Crossfire
1) first time I did this I pulled all the water into the engine. SEVERAL times so I gave up.
How long should the tube from the manometer to the engine be?
2) Does anyone know where I can buy injector nozzels? I understand that the stock nozzels are little under sized for the stock manifold. I have ported mine and would like to take full advantage of the porting. Someone mentioned the Police Caprice Nozzels. Should I be looking for them?
3) My car pulls twenty inches of vacuum at idle. is that too much to use the water manometer?
I have access to a digital manometer will it work for this?
thank you for the help. I plan on doing this project next month. when I reduce my usage of the car. just trying to get ready.
1. You're using the wrong vacuum ports. You need to use the vacuum ports on the TB's that are "Ported vacuum".
2. Look on ebay (or elsewhere) for "90 pph TBI injectors". They were commonly used in the 454 TBI and marine TBI applications. Easy to get. Direct drop-in.
3. 20" is great. As I stated above you're using the wrong ports.
You can also balance them by closing them both, until the plates bind in the bores. Then adjust the balancing screw such that they BOTH crack open from "bind" or fully closed, at the same time. Then re-set your minimum air. That method works and is easy.
What is the pph of the stock TBIs?
Can I put a fuel pressure gauge inline between the two TBIs?
Thanks for all the help. really excited about getting it running corrrectly.
The ported vacuum ports are extremely sensitive to the throttle blade's position next to the port. This is why it's used as a device to align the two plates. If the minimum air (aka idle speed screw) is adjusted correctly, there should be some vacuum at the ported vacuum ports. If there is none, the throttles are closed beyond the ports, or open way too far.
Again, you can completely avoid the complexity of messing with vacuum, manometers, etc. and simply align the throttle plates mechanically, and that will be plenty "good enough".
Stock injectors are something like 65 and 63 PPH. They aren't the same front/rear in an attempt to improve even fuel distribution, but in my experience, the "staggered" set up isn't necessary and does nothing meaningful. At any rate, stock injectors are in the mid 60's pph. You should be able to find injectors in a pretty wide range of flow ratings; they were used in everything from the 90hp 2.5L "Iron Duke", all the way up to the 235hp Chevy 454SS truck, and more recently, up to ~330hp in marine applications. Because the fuel pressure is so low, you can make large fueling changes with fuel pressure; changing the pressure 1 PSI in a 13 pound system is a far greater %change than 1 PSI change in a 40 PSI multiport system. So there is quite a bit of flexibility there.
You can install a fuel pressure gauge any where you want, before the rear TB (where the regulator is). It's probably best to install the gauge after the filter. In line between the TB's is a handy place -once you do the work to fabricate the hook up. I never bothered w/that; I'd simply "T" into the rubber hose, between the frame and the engine on the rare occasions that I needed to check or adjust pressure, then I'd remove it all when done.
So I want to know the fuel pressure from the filter to the TBIs and then I want to know the Fuel pressure from the front to rear tbi. But why does the other TBI have a regulator two regulators. does the regulator control the fuel to the injector nozzel?
It seems like only one of the regulators serves a pirpose.
I bought the car because it was a late production car with the Doug Nash 4+3 and low mileage. It definitely was not well taken care of. I am just amazed at how people cheap out with their modifications and repairs. When I bought the car the P.O. gave me a coffee can filled with extra screws, nuts and bolts that was handed to him by the previous owner to him. The car used to creak and moan with every bump. Amazing when you replace the interior screws a lot of that noise disappears.
The only engine mod has been the removal of the air pump and a cat removal with Magnaflow mufflers. Thankfully the P.O's did not do a carb conversion.
The interior is done. I've recently replaced the head gaskets, timing chain, water pump and radiator. Next year a new clutch and the DN 4+3 transmission will be rebuilt.
My only issue is no air, no heat and no cruise control. Which has to be a vacuum leak. But that can wait unitl next spring.
I also have a '91 with a 6-speed with the FX3 option, that was well cared for and needs nothing. But I have great fondness for my '84. I really enjoy working on it.
And I had a GMC with TBI ran AWESOME. So I have faith that after all is said and done the car will perform very well.
