L98 engine rebuild
Old Jan 17, 2012 | 03:08 PM
aklim's Avatar
aklim
When C4 gas gauges read low they are LOW on gas. Keep more in it bet that fixes your problem. Know electric pumps like to be submerged in gas to keep cool. Run them low a lot and they burn up quick.
The FIRST intake would work real well with the cubes and the smallish cam. Theres other choices also but thats a start.
Old wives tail. IF it generates that much heat, would you want that submerged in your fuel tank any more than a lit match? When cools the pump is the fuel running thru it from what I can see. Further to that, when you run out of fuel, your pump stops because the engine stops. IF that were true, you should buy stocks in Walbro since I never fuel up till I get to empty and more. I changed my Vette pump because I wanted a better pump. I changed my Firebird pump because the tank was getting rusty and wanted to do it with the tank out. My Merkur had 2 pumps and the outer one failed.
I went with the HSR because that is what the tuner preferred with his cam.
