Please help! I got the shakes
Old Jan 17, 2012 | 09:18 AM
1985c4vette's Avatar
1985c4vette
Default Please help! I got the shakes
1985 c4 5.7L coupe 4+3 manual trans. Has a shake at idle (like big engine shake from side to side slow), but while accelerating in each gear it gets worse as you push on pedal. If I turn on the overdrive(+3 part) in fourth gear it feels like the car is going to jump apart (only when you push the pedal). I have checked the timing (@ 6 degrees BTDC), all new distributor cap, rotor, coil, plugs (gaped @ .0035), wires (all double checked), throttle positioning sensor, and valve cover gaskets. Any ideas? Thanks! Scott.
Old Jan 17, 2012 | 09:49 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Check the engine mounts.
Old Jan 17, 2012 | 06:46 PM
1985c4vette
i will thanks
Old Jan 17, 2012 | 08:12 PM
1985c4vette
Guys and Gals, I do wish to Thank You all for your help. It 's great to find a place like this where people will help. You people are Great
To Please help! I got the shakes
