attention all C4 builders!!!!
Old May 12, 2002 | 12:13 AM
400Vette's Avatar
400Vette
Default attention all C4 builders!!!!
Hey guys I m puttin a motor in a 1984 C4 for a buddy he bought the car with no motor or tranny.... So what i need to know is there any thing i need to look out for ? Any problems you guys have had in the past doing this same job ? I own a Vette but have never had to pull motor ... :confused:
thanks for any advice :cheers:
Old May 12, 2002 | 01:01 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: attention all C4 builders!!!! (400Vette)
Should be the same as any other motor install.
Maybe get a service manual so you know where to hook up all the wiring.
Old May 12, 2002 | 04:24 AM
vettl83's Avatar
vettl83
Default Re: attention all C4 builders!!!! (Mr Mojo)
I believe the computer in the 84 is programed around the crossfire injection system. So if you are going to run a L98 or LT1 you will most likely have to up grade the computer to a later model ECM. A company called Painless Wiring has the adapter harnesses. Good luck p.s. don't forget to upgrade the fuel pump too.
Old May 12, 2002 | 06:20 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: attention all C4 builders!!!! (vettl83)
Let us know how things turn out....
:cool:
Old May 12, 2002 | 10:03 AM
400Vette's Avatar
400Vette
Default Re: attention all C4 builders!!!! (Sharky Guam)
I m not so worried about the act of installing the motor .....its more like the front of the motor .....and such, its going to be carbed.......so dont need computer ......i got a manual i m hoping everything comes out ok.. :crazy:
Old May 12, 2002 | 07:03 PM
blk90rdstr's Avatar
blk90rdstr
Watch for hood clearance with an air cleaner. you need to run electric fans. A small block is the same in 84 as most of the smallblocks so should be real straightforward. Are you using the accessories off a X-fire engine? Pwr steering , alt. etc.? :smash:
Old May 12, 2002 | 08:10 PM
400Vette's Avatar
400Vette
Default Re: attention all C4 builders!!!! (blk90rdstr)
power steering yes ........thats all he has ......going to try and find the front off of an old 350 will that work? :confused:
[Modified by 400Vette, 12:11 AM 5/13/2002]
To attention all C4 builders!!!!
