Differnce between cat-back and just muffler?
Old May 12, 2002 | 12:06 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
Default Differnce between cat-back and just muffler?
I've been looking at some exausts, and noticed that you can usually get either a whole cat-back system for about a grand, or for about half that, get just the muffler.
Is there a huge differnce between the two? Would i be happy just getting the muffler part, and saving the $$?
BTW: I was looking at the Corsas. :D
Old May 12, 2002 | 12:27 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Differnce between cat-back and just muffler? (Mervz)
You can get the Corsa system for around $800 and worth every penny.
With the whole cat-back, you get an engineered system. If you get just the mufflers, you are mixing the factory with aftermarket and may not get the optimum benefit that you would by getting the whole system.
The Corsa system includes a crossover or "H" pipe that isn't in the factory setup.
Besides with a cat back, you don't have to do any cutting and it will be a lot easier to switch back to stock if you chose to.
Old May 12, 2002 | 05:32 PM
carter200's Avatar
carter200
Default Re: Differnce between cat-back and just muffler? (Mr Mojo)
Yea, what Mojo said :yesnod: :seeya
Old May 12, 2002 | 05:40 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
ok, you convinced me... :cool:
Old May 12, 2002 | 05:44 PM
morphious's Avatar
morphious
Default Re: Differnce between cat-back and just muffler? (carter200)
I agree if you are going with the Corsa's get the whole system. Installation is pretty straight forward, all parts are included and you can do it yourself and save labor. With just mufflers you will probably have to pay for labor at a muffler shop so the can cut and weld the old off and the new on. I installed mine by myself and took an afternoon with some beers and not rushing. :cheers:
Old May 12, 2002 | 10:00 PM
stockred96's Avatar
stockred96
Default Re: Differnce between cat-back and just muffler? (morphious)
Mr Mojo, Where can I get Corsas for $800.00???
To Differnce between cat-back and just muffler?
