Polished Wheels - To Clear Coat or Not?
I've been polishing my aluminum wheels. I've read about most factory aluminum wheels having a clear coat on them. I've also read that clear coat doesn't stick well to polished wheels, and will flake off over time.
Just don't want to mess up all my hard work with a clear coat if its just going to yellow or flake off. On the other hand, not sure how difficult it will be to keep the polished wheels looking nice without a clear coat either.
Looking for experience here, either way.
Most (if not all) factory aluminum wheels are clear coated.
Most aftermarket polished aluminum wheels are not.
In other words, you can't "polish" a clear coated wheel without destroying the clear coat finish.
The factory clear coat will last for many years, but can eventually peel if not taken care of.
On the other hand, polished wheel require a lot more work to maintain that "polished look".
Uncoated aluminum will begin to oxidize as soon as it's exposed to the atmosphere.
So, you will be polishing them frequently.
They do make products that are supposed to help "seal" the aluminum after you polish them.
I have polished aluminum without clear coat, and I use a wheel sealant after polishing up the wheels.
I use the Poor Boys sealant and it keeps the luster of polishing a lot longer than before I started using it.
Takes a bit more time to seal them up, but for me it lasted the whole driving season without having to polish them up again.
I believe "Mothers" even makes a polishing kit that includes a polishing pad you can put in a drill. This will take much less time then doing them by hand...WW
My sawblades are pitted and some areas are flaking off as well. I've looked at having them re done @125.00 /wheel
So how did you remove and what clear would work the best. I know Gordon had stripped a wheel he was using as an air hose reel with some aircraft stripper and re cleared it. But the clear he used yellowed in a couple of years.
Better product to use?
The previous owner had removed it already. Aircraft remover should remove it. They had painted the inserts red. I've been using aircraft remover to remove the color.
Received 3,043 Likes
St. Jude Donor '05
No clearcoat, polish it and leave it alone.
