c4/89 COLD START PROBREM
Old Jan 24, 2012 | 09:45 AM
carlosvette89's Avatar
carlosvette89
7th Gear
Default c4/89 COLD START PROBREM
I can't get my vette runing when the engine is at ambient tempeture ill take from 5 to 10 cranks before I can get it running. After the car reach opperating tem. it will run at the first crank. I replace every censor including, ditributor and ECM. Please help.
Old Jan 24, 2012 | 10:23 AM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
How's your fuel pressure when trying to start? I had a similar problem with my 89 and it ended up being a fuel pressure regulator. You can attach a fuel pressure gauge at the Schrader valve on the fuel rail to get a reading. Unfortunately I don't remember what the reading should be.
Old Sep 24, 2013 | 10:46 PM
carlosvette89
7th Gear
I took a reading in all the injectors on my 89 vette when hot and they reads as follow, all thereadings are in ohms. #1=19.0, #2=14.0,#3=19.6, #4=19.6, #5=13.0, #6=20.0, #7=14, #8=20.0: someone please tell Me if this is the cause of My starting problem, also took a reading whiht the Ps gauge and the reading was 48 PSI, after several minutes the pressure drop to 30 psi. need help. Thanks
Old Sep 24, 2013 | 11:10 PM
hooked073's Avatar
hooked073
I would put a scanner on it and see what the temp sensor is reading in relation to app wngine temp. do this in the morning after the car has sat all night.
Old Sep 24, 2013 | 11:47 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
It could also be a failing fuel pump. Sometimes they act that way before failing.
Old Sep 25, 2013 | 12:16 AM
Netfly's Avatar
Netfly
One possible cause is the fuel pump relay. If it goes bad it takes several seconds of cranking for the oil pressure to build and then oil pressure override circuit activates the fuel pump.
Old Sep 25, 2013 | 12:23 AM
vetteoz's Avatar
vetteoz
Originally Posted by carlosvette89
I took a reading in all the injectors when hot
Given your problem is when cold starting ,what are the injector readings when cold?
Old Sep 26, 2013 | 12:39 PM
carlosvette89
7th Gear
Theinjectors reading when cold is betwing 18.1 and 18.4 in all 8 injectors.
Old Sep 26, 2013 | 12:41 PM
carlosvette89
7th Gear
While cranking the engine wiht the PG. hook up stays at 48 psi.
Old Sep 26, 2013 | 02:56 PM
MrWillys's Avatar
MrWillys
If you put your foot to the floor it will go into flood clear mode. If your injectors are leaking this should allow it to start faster, and you'll know the injectors are bad.
Old Sep 30, 2013 | 08:26 AM
carlosvette89
7th Gear
Any body out there Knows the ohms for the 89 vette injectors cold and hot whent they are good, please help.
Old Sep 30, 2013 | 11:54 PM
Cliff Harris's Avatar
Cliff Harris
Just what I was thinking...
To c4/89 COLD START PROBREM
