91 rear defogger problem.
Old Jan 24, 2012 | 01:55 PM
GKK's Avatar
GKK
Default 91 rear defogger problem.
The rear defogger on my 91 Vette times out after only 4 minutes.
The other day it was working just fine. Both side mirrors heat up and all fuses and the grid continuity are good. I also, checked all four connections on the struts and they are fine.
Could a bad relay be causing the defog light to go out? Thanks
Old Jan 25, 2012 | 03:06 AM
GKK's Avatar
GKK
Update:
The rear defogger is working again!
All I did was clean the two bottom strut connectors nearest to the cab with a small wire brush. Now, the rear defogger stays on for exactly 10 minutes and clears the rear window completely.
Also, I found on a 91 Vette, the rear defroster Relay is located under the passenger side knee panel mounted to the dash frame. There are 5 identical relays mounted next to each other and it's the one on the end nearest to the center console.
