Skip shift relay removal
Thanks in advance,
Brad
http://www.mamotorworks.com/corvette?frame=3.721
When I bought mine it was disconnected, I ended up putting the plug on there mainly to keep the crud out of the connector in case it ever needed to go back?
The manual has more detail.
It is an electric solonid that prevents the shifter from allowing movement into any gear lower than 4th.
There are very unique conditions that need to be met in order to active this solonid.
This "feature" allowed the Corvette to pass the fuel economy tests and not incurre the gas guzzler tax.
It has been installed on every 6-speed Corvette, even the new ones.
There are plenty of aftermarket kits to disable it. On early cars, you could just unplug it. But the later ones would throw a code.
You can also just accelerate a little more (past the limiting RPM range), and the light would go out allowing you to shift into 2nd.
Even if you install an eliminator, the light on the dash will still come on.
But the solonid won't force the shift into 4th.
100% correct
You can also get it programmed out in a tune. I hated the skip shift thing - always seemed to engage at the worst possible time.
Consider you have to pay shipping for the bypass plug too!
Just look at the link in post #2. Open the tech instructions and you'll see a clear diagram of the plug you need to UNplug. Wrap reliable tape about each end to keep it clean -- if you ever want to reconnect it.
I bought the CAGS bypass before I realized this easier/cheaper approach. It's been happily unplugged for 10yrs.
FWIW, I think the CAGS system is somewhat dangerous -- as it may prevent you from hitting the gear you plan to hit in a quick moment of decision. I HATE IT!!!
If I remember correctly, somewhere around the 1500-1800 RPM range, the light will go back out and the solonid won't force the shift to 4th.
CAGS only forces the shift to 4th in a very narrow RPM band.
In any kind of spirited driving, you will never be bothered by it.
I think it's a great solution. Those that buy their cars new avoid the added tax. It can be easily disabled, even on the C6, if staying in first gear an extra couple hundred rpm is so troubling.
For most, you will never know the feature is there.
The system will only force the skip shift under a very narrow RPM range.
Stay in 1st gear just a little longer, and it won't interfere with your shifting.
If you try to shift out of 1st under approx. 14 mph "skip shift" will come into play.
Hold it in 1st until approx. 15-20 mph (1800-2400 RPM) and "skip shift" won't affect you.
The car is very capable of hitting 50 mph in first gear if you wanted to hold it to red line.
Nobody ever wanted it, certainly not the engineers at GM Corvette. You can THANK the Federal Government for forcing such a wonderful idea as CAGS on the population !@#$@$!~#~
The irony is the people who don't mind CAGS enjoy revving higher to defeat the system. Ironically, that means it's installation encourages some drivers to push their cars into a slight lower mpg situation than "normal".
You have to love the irony of that!
By contrast, while learning to tune my stroker mod, I learned the engineers actually built-in a MPG adder to the ECM software. In "highway mode", the engine would lean out and advance timing -- to improve mileage. Best I can tell, the government said THAT was cheating and made them disable it.
So, the easiest MPG-saver to disable is the one that was implemented. And, if you don't disable it, you probably drive your car in a manner which uses a hair more fuel than w/o it. That's real government in action.
I also don't really think it helps me on gas, I tried to use the feature for a whole tank of gas, shifting from 1st to 4th, and then the next tank I just shifted through all the gears normally, and got around the same mileage. As long as your not going over 3500 rpm on each shift your mileage will be pretty decent!
