Car Horn
Old Jan 31, 2012 | 05:46 PM
kdtomczak's Avatar
kdtomczak
Default Car Horn
Anyone know the path of the car horn's electrical wiring? Mine stopped working and im trying to troubleshoot but i want to have an idea of where it all runs and is supposed to be before i do anything.
Old Feb 1, 2012 | 01:49 AM
Cliff Harris's Avatar
Cliff Harris
Take the "divide and conquer" approach. Isolate the problem to the horn switch/steering column wiring, horn relay and horns.
When you press the horn button the horn relay should click even if the horns don't sound. It's located behind the switch panel in the center cluster. If there is no click then it's probably a fuse or a problem in the steering column.
Here's the diagram from the Factory Shop Manual (you really should have a FSM):
