I have a 1986 Corvette and somthing is wrong with my Digital Dash. When i turn the car on the cluster lights up but doesn't display any information; turn signals, mph, rpm, etc. I was in the process of removing it but decided i should post something on here incase there was an easy fix i was missing. Any responses would be greatly appreciated.
I used the above site to repair mine.
Did it twice (2008, 2009). Dash crapped out again in 2010.
Sent it to that e-bay guy (I did it off-line and called him) in CT back in spring of 2011, for rebuilding.
Cost me $400.00. Got a new power supply and info display for the data center (MPG,Volts,etc). UV re-coated the other displays . Works and looks like new.
Alright, I'll probably just continue to remove the dash and see if i can get lucky and fix something, even though i don't really know what im looking for.
