power steering help
Old Feb 4, 2012 | 10:57 PM
pologrn95's Avatar
pologrn95
7th Gear
Default power steering help
the other day i took my car out for a little drive. when i got home i pulled in the driveway, waited a while, and when i started the car back up i had no power steering. i pulled back out of the garage and popped the hood to find power steering fluid all under the hood,belt,chassis,etc..so i thought a high pressure line had cracked.so today i fired the car up to see what line had broke and i had no leaks.the reservoir is full and i am completely confused on what is going on. if anyone has experienced something to this nature or knows what might be going on with it, i would greatly appreciate it.
Old Feb 4, 2012 | 11:14 PM
enventr's Avatar
enventr
Let someone turn the steering wheel slowly while in park or neutral while you watch under the hood for leaks.if you have any leaks under a load it will show itself.turn the wheel all the way left then all the way right.let us know your results.
Old Feb 4, 2012 | 11:20 PM
HAD2HAV2's Avatar
HAD2HAV2
You did not mention your C4 year and miles. Being that the car is unfortunatly getting old, I own an 88 so I know, and if the Rack & Pinion steering rack has never been changed, that might be a possible cause.
Old Feb 5, 2012 | 12:17 AM
Frizlefrak's Avatar
Frizlefrak
The rack may have popped a seal....and it only leaks in a certain position. The problem didn't go away....clean it up and get a helper to turn the wheel with the car running while you watch.
Old Feb 5, 2012 | 12:36 AM
383vett's Avatar
383vett
Your neighbor "overhauled" your car.
Old Feb 5, 2012 | 09:38 AM
pologrn95's Avatar
pologrn95
7th Gear
the car is a '95 and has 15.500 miles and is all original. i had my wife steering the car while it was running and didn't see nothing. unless you think a seal in the rack went bad, what would it matter being under load?
Old Feb 5, 2012 | 10:20 AM
enventr's Avatar
enventr
I once had a car with a similar problem.with the motor running I could not find the leak.I had someone turn the wheel slowly while I checked for the leak.I then saw the leak .it leaked in a certain position only.under a load you will get higher pressure and the leak should be visible.I also remembered someone told me that if the fluid leaks on a hot exhaust it could be flammable.
To power steering help
