1086 corvette
Old Feb 6, 2012 | 12:25 PM
citefarmer's Avatar
citefarmer
6th Gear
Default 1086 corvette
I just got a 1986 corvette. It sets real low in the front. What do I have to do to fix problem?
Old Feb 6, 2012 | 12:35 PM
oldalaskaman's Avatar
oldalaskaman
lower the back
Old Feb 6, 2012 | 12:38 PM
Frizlefrak's Avatar
Frizlefrak
Post a pic so we can see how low is low. But if it's abnormally low and hasn't been modified, the front monospring is sagging. Replace monospring.
Old Feb 6, 2012 | 12:41 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by oldalaskaman
lower the back
About as helpful as saying "put air in the front tires"
Take a look under and see what was done to make the front lower. Do you have a friend's Vette at stock height you can compare to and see what is different?
Take pics of the front suspension etc and post them on here - obviously someone liked the lowered look and it's a matter of reversing what they did.
Old Feb 6, 2012 | 12:46 PM
oldalaskaman
your right , havent had my coffee yet, I'm very sorry
Old Feb 6, 2012 | 12:55 PM
383vett's Avatar
383vett
I thought that was a good answer. If the back is jacked, the front will be lower. Maybe we all need coffee.
Old Feb 6, 2012 | 01:03 PM
oldalaskaman
really hard to tell without a picture
Old Feb 6, 2012 | 01:46 PM
Vette Daddy's Avatar
Vette Daddy
Sarcastic humor. I like it
Old Feb 6, 2012 | 01:53 PM
oldalaskaman
didnt intend it as sarcastic, mine seemed to be sagging in the front when I bought it , but the nuts on the rear spring bolts were showing about 2.5 inches of threads each above the pins, lowered them to the pins and leveled the car.
Old Feb 6, 2012 | 02:32 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I liked the "lower it" comeback too. Seemed funnier when we thought it wasn't totally serious tho! LOL
Front monosrings...especially on earlier C4's are known to have an issue with delamination. (Maybe this should be on prospective buyer's checklists.) I bet that's the problem with the OPs car. Probably does need a new front, transverse spring.
Old Feb 6, 2012 | 03:17 PM
hitmanpty's Avatar
hitmanpty
ok when I first buy my car, I had the same problem. I even post the question about the front been so low.
some of the members sugest me to lower the back. in fact the back was very high compared to the front.
so I when out and get me the screws to lower the back and I did.
the front is low but now look very good. and even.
the real problem is the monospring. is old and it have to be change. but they cost money. and will cost a lot more to install.
Old Feb 6, 2012 | 03:18 PM
dukeallen's Avatar
dukeallen
What a letdown. I was expecting to see a 926 year old car.
The front sag on those was easier to fix. Replace the dead horse.
Old Feb 6, 2012 | 08:33 PM
cttech455's Avatar
cttech455
lol
Old Feb 6, 2012 | 08:35 PM
mike100's Avatar
mike100
People trim the front spring bushings and also sometimes remove the sping shims. You can put more shim plates back, but you can't add cut-off rubber. Need a new stock spring or you may be able to wedge some material in there depending
Old Feb 6, 2012 | 09:38 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Mine sat so low in the front the tires rubbed the insides of the wheel well. Both shocks were collapsed. Check the shocks first they are way easy to remove and check,
Old Feb 6, 2012 | 09:56 PM
flipr78's Avatar
flipr78
lower the back
Old Feb 6, 2012 | 11:17 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Good recovery.
To 1086 corvette
Old Feb 6, 2012 | 11:44 PM
oldalaskaman
Originally Posted by JrRifleCoach
Good recovery.
sometimes ya gotta think quick
Old Feb 7, 2012 | 12:11 AM
1963SS's Avatar
1963SS
Can you get two fingers between the top of the wheel opening and the tire? We knead to no what u think two lo iz.
Old Feb 8, 2012 | 12:36 AM
Chewch87's Avatar
Chewch87
I have a similar problem with my 87. It has worsened over the years . My shocks are fairly new so Im betting on the front mono spring.
