Replaced the belt last Spring & now the new one is flaking apart right in the middle of the belt on the smooth side! Could this be just a bad belt or could it be a bad tension pulley or Idler or whatever, we're only talking about 3000 mi on the new belt. Any ideas? :confused:
Theres two belts, the right one and the wrong one.
The right one has ribs on both sides, the wrong one has a smooth side.
GM recomends to use only the 2 sided belt.
HTH
HTH
