Corrosion X
Old Feb 12, 2012 | 10:11 PM
hogsnvettes's Avatar
hogsnvettes
Default Corrosion X
I've been using this for over 20 years and have never been disappointed. If you need to remove or prevent corrosion on any metal, this is the stuff. I use it on connectors, bulb sockets, switches, practically anything that needs protection against corrosion, and it is a dielectric. By the same company that makes Rejex.
http://www.shop.corrosiontechcorp.com/CorrosionX_c2.htm
Old Feb 12, 2012 | 11:37 PM
dogfish246's Avatar
dogfish246
Is it a similar consistency to WD-40?
Old Feb 12, 2012 | 11:55 PM
hogsnvettes
Not even close. I only use WD40 when I want to remove moisture from something. Corrosion X removes corrosion, prevents further corrosion and is great for electical connections. I've used it on battery terminals for years. I reapply about once a year and never have corrosion buildup.
Old Feb 13, 2012 | 12:06 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Huh. I never put anything on my battery terminals...and I too...never have corrosion build up. My way also works and it's FREE!
Just out of curiosity, do you use seafoam to keep your engine clean, too?
Old Feb 13, 2012 | 12:08 AM
hogsnvettes
No.
To Corrosion X
