Heater core
1. Take your dash apart to get to it.
http://forums.corvetteforum.com/c4-t...placement.html
2. Lay on your back and get to it that way.
http://forums.corvetteforum.com/1569252027-post4.html
http://forums.corvetteforum.com/c4-t...ater-core.html
Either way sounds like a pain in the keester.
I have a pdf of taking the dash apart that is different than the one in the first thread I found. Send me a PM with your email address and I will send it to you if you want it.
Kevin
Fastguy Method
Here it is, and yes it can be done this way in 4-5 hours. Of course I fit under under there, if you're a big guy this may prove a little more challenging.
Almost forgot, you might want to pre-buy the little plastic clips that hold the heater door control rod, these will be very brittle and you'll probably break them trying to get them off.
Here's to the author
FASTGUY
Whoever wrote that huge "pull the dash out" article was a friggin' crackhead.
You don't pull the dash, instead, pull the passenger seat.
Pull the hush panel, drop the ECM and the door control module.
Remove the support bar going from the door pillar to the dash.
Use a 7mm to take the cover off the heater box.
Pull the cover, unbolt the core, re-install.
Drink beer and laugh at webpage showing guys pulling dash.
Just did it on my '89 2 weeks ago. I removed the diagonal brace. There are 5 screws on the plastic cover for the core - 2 top, three bottom/sides. There are 3 screws retaining the core itself - 1 top middle & 2 bottom. As said, watch the position of the rod on the motor that opens/closes the door (if you have electronic controls). BTW, I also took out the pad in addition to the lower access panel - 4 nuts & much more room if you have full size American arms & hands. I got the upper screws restarted by placing a bit of tape on them & wedging them into my 7mm socket. It helps to have 1/4" drive flex adapters and every extension length they don't make Total time for me was about 5 hours for the heater core in-and-out. Plus a couple of hours to fix the broken dash frame and to eliminate the breadbox - not necessary, but seems to add a lot of "room" inside & looks way better One more thing - since you're there inspect all wires & the orange vacuum line. I found two damaged wires & a missing heat shield on the courtesy lamp. My new heat shield is two thicknesses of Bud can
This job is a PITA I believe the Heater core is part #000000000001 and then they built the rest of the C4 around it. Pre 90 your best advise is to pull the passenger seat and use the "Fast guy" method.
Vettes are a bit strange. When I tell people that I had to remove the rocker panel to change the battery they think I'm either lying or crazy.
