select ride control
Old Feb 27, 2012 | 04:52 PM
Smokeysvette's Avatar
Smokeysvette
Default select ride control
On my newly purchased 1992...
Upon cold start-up I get the "Service select ride control soon" light. But if I cycle the key once it goes off never to come on again while driving. Then the next day on the first crank (initial start up) it came on again. I cycled the key once again and it goes off and will not come on again until it's started the next day. Again it won't come on again as long as the car is being driven. Today i went out and it never came on at all.
Any simple idea's where to start?
Thanks in advance
Smokey
Last edited by Smokeysvette; Feb 27, 2012 at 04:59 PM. Reason: added the year model. ;-)
Old Feb 27, 2012 | 05:14 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
First thing I would try is to clear the codes, and then see if if happens again. (I'm assuming you read the codes already.)
Old Feb 27, 2012 | 05:33 PM
Smokeysvette
No haven't read the codes as of yet. Does the 92 still use the OBD II? using an ALDL connector or just jumping A to C with a jumper?
Old Feb 27, 2012 | 05:41 PM
GreyGhost's Avatar
GreyGhost
It will also come on if you start the car three times without the car moving. I would just clear the codes and keep an eye on it.
Old Feb 27, 2012 | 05:52 PM
92ragtop's Avatar
92ragtop
You can jumper the connector. Do a search for "paper clip" method.
Old Feb 27, 2012 | 06:01 PM
Smokeysvette
Thanks guy's!
Yea, just found out it's the same old OBD II with using the ALDL to see the codes. When I get home I'll check it out and see what I find. Yes! I have started the car with out moving the other day and possibly that's it. Thanks for the info on that one. Damn who woulda thunk it....LOL
I'm familiar with the older OBD II as my 89 Chevy Dually uses the same system. (OBD II)
Old Nov 7, 2012 | 09:53 AM
rudym43's Avatar
rudym43
2nd Gear
How do I clear the codes?
Old Nov 7, 2012 | 07:30 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Disconnect the battery for a short time (can't remember how long but a minute should do it).
Old Nov 8, 2012 | 08:01 AM
bac22's Avatar
bac22
Turn the key to on too
Old Nov 8, 2012 | 10:55 AM
Red Dwarf's Avatar
Red Dwarf
Thanks in advance
Smokey
This has a lot of info on the system.
http://www.corvetteactioncenter.com/...l#.UJvVscXA98E
Old Nov 10, 2012 | 10:17 AM
lvm94's Avatar
lvm94
1992 had a obd 1 system not obd 11
To select ride control
