Lights flickr @ idle
Checked the alt , engine off : 12.5 , engine running : 14.8- 15.0
I didn't find lose wire and I don't know the location of the ground wires .
I found the left knock sensor wire was cut !!!
Is there any info where can I find all the grounds ?
They are flat and braided
Two common faults of AC ripple are a fault within the voltage regulator circuit itself, or a problem with the field connection. Grounding connections are also important, but the alternator gets it grounds from the block which is connected by a large cable connected to the negative terminal of the battery. Usually, a ground fault on that link will cause problems with the starter, etc, LONG before it will result in a charging issue. But! Never assume!
Right off the bat, the voltage is a bit out of the normal high side of the regulation window.
As a rule, the voltage \is typically around 14.5-14.6 (cold engine, or low as 13.5 on a hot engine that has been running for a while). The key (again) is that ripple. Is the voltage steady or fluctuating a few tenths? You say 14.8 to 15.0, but is that steady, or is it constantly varying between the two?
I don't have a figure for what is normal, far as ripple goes, but if you're seeing it in the dash and the headlights, it will have to be upward of a half a volt or more. (I'll get back with more info on that)
Most meters, but not all, will read fluctuations or "ripple" on a DC source. Usually, one simply selects the "AC" (~) mode when measuring the DC voltage, and some meters have a dedicated DC/AC combination function, and some digital meters also have bar graph - usually at the bottom of the screen. (The bar similates an analog measurement by displaying amplitude. It should be steady, or toggling no more than a single segment. (Note: Digital meters break an analog voltage into incremental steps. If the analog voltage is right at the threshold of one of the increments, a tiny fluctuation will cause the next higher step to toggle on and off according to "noise" on the analog voltage.))
In the mean time, check the field connection on the back of the alternator - clean it if necessary, and if negative connections on the block and both the connections on the battery are cleaned, and the problem persists, my money is on the voltage regulator in the alternator.
As for most of the peripheral circuit grounds, the grounds are usually found on the bolts that hold the belhousing or transmission to the block. They "might" be a bitch to get to.
More later.
P.
Obviously, the knock sensor wire should not be cut. The question I have is "why?".
More later.
P.
