PKE remote - am i missing something?
Old Mar 6, 2012 | 06:42 PM
Joe C's Avatar
Joe C
Default PKE remote - am i missing something?
(96 coupe) - from what i'm reading in the owners manual, there seems to be only two modes available for programming. one where the doors lock/unlock when the fob is in close proximity top the car, and the other where you can unlock the passengers door and the hatch using the fobs buttons. the lock/unlock in close proximity is a royal pain in the ****. it seems to me there should be a mode where i can unlock the drivers door using the fobs buttons. AM I MISSING SOMETHING OR HAVE I OVERLOOKED SOMETHING IN THE OWNERS MANUAL?
Old Mar 6, 2012 | 07:01 PM
Illini Al's Avatar
Illini Al
St. Jude Donor '10-'11-'12-'13-'14-'15
Unfortunately, the fob cannot be used on the Driver's side door, period. The door button on the fob can only control the passenger door.
Old Mar 6, 2012 | 07:48 PM
Larry/car's Avatar
Larry/car
You can turn the lock/unlock feature on or off easily by holding the door lock button until you hear the door relay cycle. I use it all the time.
Old Mar 6, 2012 | 08:05 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
As mentioned, you are understanding the functions correctly.
I also do as Larry mentioned, and just leave the system off unless I am going to be out of sight of my car.
While home, I just leave the auto lock/unlock function turned off.
If I am out and about (Hotel or restaurant when car is out of sight), I will turn the system on.
The system works great, and I like just being able to walk up to/away and have the car lock/unlock as needed.
Old Mar 7, 2012 | 10:30 AM
markKlein's Avatar
markKlein
That's how it works. Just turn it off if you are going to be pumping gas or workng around the car.
Old Mar 7, 2012 | 11:14 AM
Joe C's Avatar
Joe C
that's what i did today after reading some of the replys. still seems like a royal PITA. kind of like the fobs on the C5 and C6 better...
Old Mar 7, 2012 | 12:59 PM
markKlein's Avatar
markKlein
Given the choice I would pick a standard method, but once you used to it it isn't so bad, can even be handy to unlock the doors when you have your hands full.
Old Mar 7, 2012 | 02:04 PM
RollaMo-LT4
Of course they are better, as they should be.
Technology keeps marching forward.
The key fob for our new Camaro has a button on it, so the actual key part folds back into the fob (like a pocket knife).
It also has remote start.
I am sure nobody would want to go back to any of the first generation cell phones either.
Old Mar 7, 2012 | 05:42 PM
Klondike's Avatar
Klondike
There is a way you can program the doors so you can have it auto lock/unlock the drivers door only or both doors. I think it toggles modes when you insert the key in the ignition and press the fob till it cycles while you're sitting in the car. I can't remember if you have to have the ignition turned to on or not though. I do remember I had to reset it once because my wife's side didn't open when my side did. When you get it set, you can still turn the autolock on and off by standing next to the car and pressing the fob till the locks cycle, and it will retain your setting for which doors when you turn it back on. It tells how in the manual but it's a little hard to understand and took me a while experimenting with it till I got it to work.
To PKE remote - am i missing something?
