The pickup point is in the tailshaft of the transmission. There's a VSS (vehicle speed sensor), located on the LH side, a few inches ahead of the driveshaft. The ECM counts the number of pulses received over time, and calculates the speed from that.
Of course the wrong size reat tire affect accuracy. The sensor only kows how many times the tailshaft has turned and the ratio is calculated to be correct with the correct rear gears and tire circumference. If you change either of those you will have some error. If you put in more rear gear ex. go from 2.59 to 3.07 the speedo will read high if you go to a taller tire it will read low.
WS (wheel speed) = tail shaft speed / axle ratio
(WS x 60 x tire circumference in ft) / 5280 = mph
You can buy a box that can compensate for different tire sizes and rear end ratios. I don't know the manufacturer offhand, but I'm sure there are people here who know. A friend of mine put one on his car when he went from a 3.07 rear end to a 3.54.
CCmano (Hans) has an electronic speedo calibration circuit. You might PM him.
