High Idle
Old Mar 13, 2012 | 07:03 PM
Alan777's Avatar
Alan777
Default High Idle
Ever since I bought my 91' a few months back it's had a high idle. During winter It'd idle around 1000 rpms, now it idles around 900. I thought you could adjust it manually, but IIRC I read it's electronic(computer) controlled and can't be adjusted. Where should I start looking?
Old Mar 13, 2012 | 09:19 PM
Paul Workman's Avatar
Paul Workman
For starters...
Start by seeing if you have a "vacuum leak". Pull the snorkel off the air horn and place a hard cover book over it while it is idling and see if it will remain running. If it does, you may have a leak.
Then too you might want to inspect your idle air controller to see if it is gummed or carboned up.
P.
Old Mar 14, 2012 | 04:28 PM
Nathan Plemons's Avatar
Nathan Plemons
I drove my car as a daily driver for 6 years and never had a problem. Since I "retired" it I've had this problem twice.
If the IAC is stuck too far closed the car will likely start but will stumble a lot and not want to idle until it warms up. If it's stuck too far open you'll have a high idle. If it's somewhere in between you may have a little of both.
If you decide to look into this as a possibility you want to be very careful with the IAC, they can break pretty easily. The IAC can be removed with the TB on the car, but if you can easily remove the TB you can clean it better. Remove the IAC and carefully clean the passages with throttle body cleaner. When cleaning the pintle on the IAC itself be careful, you don't want to retract or extend it or you may damage the motor, just clean it carefully with throttle body cleaner. An old toothbrush helps.
If you remove the TB it's a great time to clean it up in general and make sure your throttle blades aren't sticking as this can also cause a high idle.
Old Mar 14, 2012 | 06:24 PM
Alan777's Avatar
Alan777
I did some reading about IAC's and how careful you have to be with them. I'll have to buy a new TB gasket and clean the TB and IAC. The car is a 91' with 45k on the odometer. The P.O. didn't drive it much at all, so I'm trying to sort small stuff out.
Thanks for the insight, and I'll post updates on the car when I get a chance to clean it.
Old Mar 14, 2012 | 06:28 PM
Cavi's Avatar
Cavi
out of curiosity, what does everyone expect for normal idle, my 94 has always idled between 900 and 1000, I thought that was normal
Old Mar 14, 2012 | 06:34 PM
Alan777's Avatar
Alan777
my 88' idled at ~600-700
Old Mar 14, 2012 | 06:39 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Same with the '88 I just bought Tue.
To High Idle
