How do I remove under dash on pass side?
Old May 16, 2002 | 04:04 PM
BCinPhx's Avatar
BCinPhx
Default How do I remove under dash on pass side?
My close-up vision is not what it used to be and I can't tell if I have all the screws out of the under dash piece on the passenger side. Anybody know tricks or??
Trying to get 'breadbox' out.
Does it pull down to come out? I don't want to break the piece.
Thanks,
:confused:
I posted this on the Tech board too... Gotta get this car apart and back together today.
Thanks,
Old May 16, 2002 | 04:22 PM
JonM's Avatar
JonM
Default Re: How do I remove under dash on pass side? (BCinPhx)
On mine...both bolts needed to be removed from below...You need LONG extensions, swivels, a strong back and patience.
Old May 16, 2002 | 04:44 PM
BCinPhx's Avatar
BCinPhx
Default Re: How do I remove under dash on pass side? (JonM)
Jon,
Thanks for the diagram...I didn't have one.
Gonna try it now.
Thanks Tons,
:D
Old May 16, 2002 | 06:05 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Was not fun taking it out ! :D
That pic doesn't show the other 4 nuts you have to get out....
[Modified by Coupe89, 2:05 PM 5/16/2002]
Old May 16, 2002 | 06:06 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: How do I remove under dash on pass side? (Coupe89)
:smash:
Old May 16, 2002 | 08:16 PM
Netnarc2's Avatar
Netnarc2
Default Re: How do I remove under dash on pass side? (Sharky Guam)
I had the same problem when I was dying my dashboard and I wanted to dye the bread box. I could see the two screws located down at the bottom of the box, installed from from the dashboard side (the screws were pointing from the front of the car to the back). I finally gave up, masked off the interior and sprayed it in the car. Worked fine.
Old May 16, 2002 | 11:22 PM
BCinPhx's Avatar
BCinPhx
Default Re: How do I remove under dash on pass side? (Netnarc2)
My back hurts and my knuckle is skinned but, it's out and the new flat piece is in. Boy, now I need dash....I didn't realize how bad this one was...Arizona sun got to it.
Thanks Guys for your help.
To How do I remove under dash on pass side?
