Cracked targa?
Old Mar 22, 2012 | 06:31 PM
Speedjester's Avatar
Speedjester
Default Cracked targa?
Well I just had my targa top replaced under my glass coverage two weeks ago... The glass shop installed the targa.. They had a hard time fitting it.. But they got it on.. Today I go to take the car out for a cruise and I notice a crack on the edge.. Sticks out about a .25 from the side edge moulding.. The crack is strange I can see another crack using a flashlight further in on the acrylic.. But the two cracks are not touching..
I called the glass company that swapped the tops and left a message.. Question is what could have caused this.... Manufacturing defect?? Car hasn't left my driveway since the install.. And nothing has hit it.. Should the glass company replace it??
Thoughts opinions??
Old Mar 22, 2012 | 07:32 PM
samsonb's Avatar
samsonb
Could not have been installed correctly, damaged in shipping, junk rebuild top, etc. What kind of warranty does the top have?
Old Mar 22, 2012 | 08:01 PM
Speedjester
I'm not sure about warranty.. I went to a glass shop..they ordered it and put it on...Do most places give warranties on targa tops.. I have only had it less than two weeks..I really can't see how it could have cracked.. Today is the first time I drove it since the install and I noticed it before I even got into the car.....
Old Mar 23, 2012 | 01:55 PM
Touchton94LT1's Avatar
Touchton94LT1
hm..sounds like it might have cracked during the "fitting" or possibly it was sorta wedged and body twisting caused a slight crack..just a guess.
Old Mar 23, 2012 | 09:38 PM
Jimbo 89's Avatar
Jimbo 89
sounds like it was under so much stress that they either cracked it or made it crack.
Old Mar 24, 2012 | 05:04 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
I assume the shop just replaced the glass panel and used your original frame and mounting hardware. While fitting the new panel the shop may have moved one of the mounting points ever so slightly, thereby requiring them to force the top into place. When fitting a new top there is a procedure for aligning the mounting points so as not to stress the top.
Old Mar 24, 2012 | 05:13 PM
Speedjester
Well the glass company first stated it was scratched... After about 30 minutes I convinced him it was cracked(very obvious).. Then he tells me he will check with the manufacturer to see if they warranty it... I have a feeling if the manufacture tells them they are not warranting it.. He is going to say Sorry but they Won't warranty it...
Wondering what recourse I have considering it was already paid for by the insurance company?
Any thoughts? Suggestions?
Old Mar 24, 2012 | 05:33 PM
PAINTER MAN's Avatar
PAINTER MAN
I would be contacting the insurance company and telling them the situation.
To Cracked targa?
