Question RE: PKE erasure?
Old Mar 24, 2012 | 02:46 PM
inedajob's Avatar
inedajob
Default Question RE: PKE erasure?
I have a 95 coupe. Suppose there have been 3 transmitters programed and they have been lost or damaged. Is it possible to erase the previous transmitter programs and start over with the ability to program 3 more? This is not mentioned in the STG manual Section 9K. Is it possible to reprogram the CCM?
Old Mar 24, 2012 | 03:24 PM
Red Dwarf's Avatar
Red Dwarf
Yes, just follow the programming instructions in owner's manual or fob instructions.
Old Mar 24, 2012 | 05:20 PM
markKlein's Avatar
markKlein
Every time you run the programming, the previous fobs will be "erased". If you add a fob to the car, you would program the new fob, and then program the old fob in the same procedure. The limit is three at one time.
Old Mar 24, 2012 | 05:57 PM
inedajob's Avatar
inedajob
Duh.......I totally missed that in the instructions. Thanx
Old Mar 24, 2012 | 06:48 PM
markKlein's Avatar
markKlein
I'm not sure it exactly says that in the manual, but if it is working right that is what it will do. We have had members in the past who were puzzuled because they programmed a new fob and the old one stopped working. Just had to do them both in the programming sequence.
To Question RE: PKE erasure?
