Spring Break Projects
Old Mar 25, 2012 | 01:06 AM
yakmastermax's Avatar
yakmastermax
Default Spring Break Projects
Came back home for spring break to find quite a few boxes waiting for me! I've got 4 days to get everything in the boxes installed onto and into the car! More pictures to come.
Nice thing about being home is that I'll have a little monkey to help me
Old Mar 25, 2012 | 10:18 AM
mmercer's Avatar
mmercer
Wow, ambitious...I've got rotors coming in and that's about it this year so far. good luck.
Old Mar 25, 2012 | 10:38 AM
HlhnEast's Avatar
HlhnEast
Looks like Christmas in March! Hope you and the monkey get your projects done. Post up when done and make sure to give the kid a ride when your done.
Old Mar 25, 2012 | 11:48 AM
ch@0s's Avatar
ch@0s
Are you going to tell us what is in the boxes? I thin k I see a set of wheels.
BTW my 9 year old like to wear shorts and boots too.
Old Mar 25, 2012 | 01:11 PM
HlhnEast's Avatar
HlhnEast
Isnt that a law or sumthin in Texas?
Old Mar 25, 2012 | 04:42 PM
yakmastermax
Bastrop morning:
Wheels indeed! 17" x 9.5" Reproduction A molds. Correct offset for the '85 so no spacers! Tomorrow i'm going to swing by discount tire and hopefully get some Nitto NT 555 275/40R17 put on the wheels
In the meantime i've got new rotors and pads to put on.
monkey see, monkey do
Just the three 10mm bolts holding the dust guard on.
Also just wondering everyone's thoughts on replacing the hardware such as the two large bolts securing the caliper bracket or the bolts holding the caliper to the bracket. My dad doesn't think it is necessary but i'm all for spending money at O'Reilly's
And sneak peak of the next project
Old Mar 25, 2012 | 10:35 PM
yakmastermax
Sorry about the cross post but I am strapped for time and need an answer fast because school starts monday and I have to be back in Colorado by Saturday! I'm trying to hook up a single sub and a power amp to my existing bose system.
A few weeks ago I learned in the audio section that I could splice a signal from the speaker wire before it went to the bose amp and route that to the power amp and then to the sub. I've gotten the carpeting up and the storage lids off and now the actual work is starting. First, I'm not sure which wire is the signal wire to the bose amp:
C4 Audio FAQ has wiring diagrams which say that the brown and yellow wire and positive and negative for the left side rear speaker. I just wanted to double check this before I cut. Also correct me if I am wrong but do I splice the brown and yellow cable into a single RCA or two? http://www.corvetteradios.com./Page.html
Second, I'm not sure how to seal my MDF board to the fiberglass and how I should prepare the storage bin / speaker box. Any tips or ideas would be greatly appreciated.
Lastly, if I want to run a RCA level **** for bass adjustment, do I put it inline before the power amp or between the amp and the sub?
Thanks again.
Old Mar 26, 2012 | 10:08 AM
MeanMachine350's Avatar
MeanMachine350
St. Jude Donor '12
I just did a brake job on my '85 as well and re-used all of the bolts along with some threadlocker 'blue'. Although make sure you clean out the old grease for the guide pins and re-grease it, and make sure the guide pin seal boots are in good shape then you are good to go.
Old Mar 26, 2012 | 11:51 AM
yakmastermax
Sounds good! Boot rubber looks fine. Is just normal red grease okay for the pins?
Another update; I took the wheels to discount and they did not have the Nitto NT 555s in stock but they're being trucked from dallas and if I'm lucky they'll have them mounted and balanced by 5pm today!
Audio issue still up in the air though.
Old Mar 26, 2012 | 03:41 PM
IAFF alumni's Avatar
IAFF alumni
Ambitious bunch of projects for a 4 day break!
Good luck!
Old Mar 26, 2012 | 05:30 PM
MeanMachine350
St. Jude Donor '12
Any high temp brake grease will work. Wish I could help you with the audio issue but I don't have experience with subs or amps.
Old Mar 26, 2012 | 06:11 PM
hitmanpty's Avatar
hitmanpty
that look like Christmas
To Spring Break Projects
