Need another spare set of keys
1994 Admiral Blue ZZZZZR1
Question
Where is the best place to buy blanks and which ones to get
They have different blanks depending on year and kind, correct?
I have a 1994. (it's a ZR-1 but I don't think that matters)
Thanks for any input
Cheers
David
Cheers
David
IIRC, there are 15 different resistance values for the pellet in the ignition key. A GM dealer should be able to read the resistance value in Ohms and duplicate the keys. Some dealers may require proof of ownership of the car (registration address must match your driver's license or something similar)
Some locksmiths also carry the GM pellet key and can also make copies.
You can get hosed by a dealer, or, you can just measure the ohms on your existing key and then order the correct blank on-line, and have it cut anywhere. That's how I did mine years ago, but I can't remember the website. Shouldn't be hard to find one though.
Received 6,980 Likes
2015 C2 of Year Finalist
yes because I had to pay a dealer 15 bucks to cut me a spare ignition, and lock key
Ordering the key on-line? Why? You need to expect that you'll receive "what you ordered" - "wait" and maybe "wait" again! Cut anywhere? What happens to your "cheap key" if it's mis-cut?
There's no particularly good argument for "not starting at the dealer"!!
Hosed? Perhaps if you patronized the dealer your experience might improve!
There's only one "keyway" for C4 VATS ignition but the "keyway" for the doors traditionally changed year to year. MY's 91+ could be the exception and are all H keyways. The "keyway" for your door will be identified by a stamped letter on the head of the key. Yours, likely an H !!
