1994 Headlight Replacement
Old Apr 1, 2012 | 03:33 PM
bugeye's Avatar
bugeye
Default 1994 Headlight Replacement
Like many C4 owners, I am not at all happy with the illumination of my stock headlights. I've done some research and have decided to purchase a pair of Sylvania Silverstars. I reviewed my FSM but still was unable to figure out how to remove and replace the old headlights. Could someone walk me through the procedure? Do I have to remove the headlight door or is there an better way to get at the retaining bezel that holds the headlamp in place? Thanks for any advise you can pass along.
Old Apr 1, 2012 | 04:02 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
open the hood. find the head light motor manual turn ****. turn motor until half the headlight motor is open. find the screws that hold on the cover on. after that is removed you will see the small screws that hold on the S/S ring that holds the headlight bulbs. unplug bulb.
all that can be found in your owners manual
Old Apr 1, 2012 | 05:04 PM
cuengineer's Avatar
cuengineer
If your 94 is like my 88, you can also get the headlights in the half-open position by turning the lights on, then turning them back to the park light position as they are opening. They will stop immediately in that position. (Note: if you just turn them on, they will open too much to get to the 4 screws holding the cover. And if they are in the off position, same issue.) You may have to play with it a little to turn them off at just the right point. Ends up being a 5-min or so job like this. Does not tell you this in FSM though.
Old Apr 1, 2012 | 07:00 PM
bugeye's Avatar
bugeye
Thanks guys for the prompt replies and information. Nowhere Man, you were right, the directions are in my owner's manual. I don't know how I missed it.
Old Apr 1, 2012 | 09:21 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Just went out and tried it, nice little trick.
Old Apr 1, 2012 | 09:59 PM
Nowhere Man
just tried that too in my 94 and it works. owned this car for 5 years and never knew this.
Old Apr 1, 2012 | 11:18 PM
cuengineer's Avatar
cuengineer
Even a blind hog finds an acorn every now and then.
I happened upon that trying to stop the lights in the right place by switching off the ignition when they were opening/closing. Never could get them to stop in the right place until I used the light switch. Took no time to change the bulb then.
Old Apr 2, 2012 | 12:35 PM
bugeye's Avatar
bugeye
Installed the Silverstars today - piece of cake. Thanks to all who replied to my post.
Old Feb 11, 2013 | 04:13 PM
C4 King's Avatar
C4 King
I know this is an old post, but do you still have your old Wagner plastic headlights? If you do and they are in working condition, I'm willing to buy them from you for a fair price.
To 1994 Headlight Replacement
