Mud flaps?
Old Apr 1, 2012 | 11:14 PM
chevyc4man's Avatar
chevyc4man
Default Mud flaps?
Do any of you have mud flaps or guards in yor wheel wells? I bought a 94 vette that haves them, they are painted torch red and actually look pretty good. I just think it might look better without them. Do many of you without them have problems with rock chips? Thanks for any thoughts!
Old Apr 1, 2012 | 11:37 PM
383vett's Avatar
383vett
Plexiglass mudflaps to protect the paint from burnouts.
Old Apr 1, 2012 | 11:58 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I had them on my 1st 35th Anni, took them off before letting it go to "salvage" and plan to install them on my 2nd 35th Anni.
They are black rubber and go well with the white/black motiff, IMO.
Old Apr 2, 2012 | 07:57 AM
corvette Stu's Avatar
corvette Stu
Where did you get them, I am using 2" painters tape now but yours look wider then the ones from the vendors ?
Old Apr 2, 2012 | 08:12 AM
chevyc4man's Avatar
chevyc4man
For non racing use do you think one really needs them?
Old Apr 2, 2012 | 10:28 AM
383vett's Avatar
383vett
Plexiglass cut with a jigsaw. Just make a template with cardboard. Costs next to nothing.
Old Apr 2, 2012 | 04:42 PM
vetsvette's Avatar
vetsvette
Depends on whether you enjoy cleaning tar off your rear quarters or front fenders.
Old Apr 2, 2012 | 04:52 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I have them on The Ghost and they work. I agree with vetsvette, the tar is a bitch to clean. I dont show Betty Boop anymore so likely I will install a set of them on BB soon.
Old Apr 2, 2012 | 04:59 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
My '93 came with them. They look good, so I left them on.
Old Apr 2, 2012 | 05:58 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
I have the clear small splash guards on my 85. You can hardly notice them as they don't take away from the body lines. I get many compliments on them because most people have never seen these type and no other cars of any make that I've seen have them.
Old Apr 2, 2012 | 06:00 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Personally, I don't care much for the look of mudflaps on a vette, although I can understand why in some areas or situations they might be a good idea.
Old Apr 2, 2012 | 06:13 PM
dogfish246's Avatar
dogfish246
I personally like them because enough stuff gets kicked up with them on!!! I dont mind the look:
Old Apr 2, 2012 | 06:16 PM
383vett's Avatar
383vett
Found this picture. This is why I need mudflaps...
Old Apr 2, 2012 | 06:48 PM
Illini Al's Avatar
Illini Al
St. Jude Donor '10-'11-'12-'13-'14-'15
Old Apr 2, 2012 | 06:55 PM
CRUZNC4's Avatar
CRUZNC4
2022 C4 of the Year Finalist - Unmodified
I bought the Altec molded splash guards for mine and love the look as well as the protection. I highly recommend them!
Old Apr 2, 2012 | 06:58 PM
93Rubie's Avatar
93Rubie
I have the clear ones Mid America makes. They work fine. Catch a lot right where you need it behind the wheel. They do not catch everything.
I still get rubber further back on my rear lower quarters but it is very minimal.
They really do not take away from the lines at all. FYI, the acrylic and auto-x cones don't mix I cracked one of them when I caught a cone. Nothing but a scuff on the paint, wiped off.
Here is a good shot of them:
Note mud line, where they caught some of it:
Old Apr 2, 2012 | 07:32 PM
corvette Stu
since I installed a line lock and the plexiglass idea seems good how thick and were you able to get it in black ?
To Mud flaps?
Old Apr 2, 2012 | 08:12 PM
383vett's Avatar
383vett
I don't have an exact thickness measurement of the plexiglass. Just go to TAP plastics and pick up some scrap that feels right. I had a roll of peel off stickum black vinyl that I had sitting around the garage. I think it was for a do it yourself fat hood stripe I never used. Autozone might still carry the stuff. I covered one side of the plexiglass with this stuff and it works great. If you have a line lock, it really helps protect the paint.
Old Apr 2, 2012 | 10:30 PM
astepup's Avatar
astepup
PO had a set of Altecs on the back and I added the front set. I like the look and living on a gravel road they sure do help. Now I get to shamelessly post a pic....
astepup said that
Old Apr 2, 2012 | 10:52 PM
chevyc4man's Avatar
chevyc4man
astepup said that
Nice Vette! Mine look like your but torch red.
