Getting some work done
Old Apr 2, 2012 | 08:39 PM
ChrisG84's Avatar
ChrisG84
Default Getting some work done
The '84 mileage is at 156k.
The transmission seal connecting to the engine needs to be replaced. I heard this was common for GM vehicles around this year.
Getting the windsheild wipers fixed. Motor only sends them a quarter of the way up the windshield. Didn't matter when I was on the highway, but around town kinda sucked cause I couldn't see
Heaters getting fixed. Apparently the prior owner bypassed the water flow going into the firewall. I just hope they had a different purpose other then bypassing a leaky heater core.
And last but not least, re-wireing the water temperature gauge. Found a bad wire right down there.
Old Apr 2, 2012 | 09:34 PM
Cliff Harris's Avatar
Cliff Harris
Are you leaking engine oil or transmission fluid?
Old Apr 3, 2012 | 10:15 AM
ChrisG84's Avatar
ChrisG84
Oh yeah! It was leaking crazy.
Old Apr 3, 2012 | 10:25 AM
383vett's Avatar
383vett
Read Cliff's question.
Old Apr 3, 2012 | 10:30 AM
ChrisG84's Avatar
ChrisG84
Leaking transmission fluid. Mechanic worked on it yesterday. Found that the housing needs to be replaced. Also found 3 engine oil leaks that he's going to fix as well.
Old Apr 3, 2012 | 11:24 AM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
I'd change out the rear main seal while you are at it, got the transmission out anyway, now is the time to do it.
Just my 2 cents.
Old Apr 3, 2012 | 11:48 AM
MeanMachine350's Avatar
MeanMachine350
St. Jude Donor '12
Might be a good time to look at the transmission while its out, see if it needs rebuilding or you could add a shift kit while you're at it.
For the heater core, I bypassed mine because it was leaking so I'm 90% sure the PO bypassed yours because it leaked. I hope that's not the case though or you'd have to take the dash out to get to the core.
Old Apr 3, 2012 | 01:09 PM
ChrisG84's Avatar
ChrisG84
Just my 2 cents.
Very good point! I'll text my mechanic now.
Old Apr 3, 2012 | 01:11 PM
ChrisG84's Avatar
ChrisG84
Man, I would love to switch it to a manual transmission. The heater is fixed!!!!! Mechanic didn't mention much about it, he just said it's fixed. A little late in the season, but it'll be ready for next season or when I'm driving at night with the top off
Old Apr 9, 2012 | 01:49 PM
ChrisG84's Avatar
ChrisG84
Ok, got the car back. Here's what the mechanic text me:
1)Replaced two rear main seals, tranny and engine
2)Fixed starter (replaced craking gear)
3)fixed seal intake manifold oil leak
4)replace front mail seal
5)fixed heater- sealed two core lines
6)fixed acceleration misfire(replace air control valve and fuel injector module)
7)replace transmission housing
All for $250 in parts and $600 in labor.
To Getting some work done
