Dash lights replacement ?s
My only clue, I don't know to what
, is that when I first turn the ignition switch on those "dead" lights show faintly.As you know, the switches are in a different bezel above the radio. Maybe I could do this later??????
I have to go in steps; my wife only allows a certain amount per month for my "mistress".. Vanna the '87 Corvette.
The new bezel for the above-the-steering-wheel post is on back-order from Corvette Central (mein Got in Himmel, $179 +/-) The former owner installed a radar detector and tightened the right upper and lower screws to tight and cracked the bezel
AND about the ignition switch--should there be an "accessory" position that allows radio, windows, seats to be moved/adjusted when sitting, waiting on one's wife while she is shopping and you are afraid to leave your car alone--especially at Walmart
