Finished!!!!!
Old Apr 12, 2012 | 11:27 PM
phat87's Avatar
phat87
2021 C4 of the Year - Unmodified Finalist
Default Finished!!!!!
After nine (9) weeks and over two hundred (200) hours of work my project is FINISHED and I drove the car today.
Stripped out the interior, put down BQuiet stick mat, foil thermal layer and new matting. Cleaned and painted all the carpet installed new weather strip and she's done.
What a frikken job! And after all that NO PICTURES! I was so into the "work" I forgot to take pictures! Dow!
Seriously, after all that work and expense when I took for a drive I couldn't notice any difference in the sound level! So much for advertising hype eh!
But I sure did learn alot about myself and about my car. I am a keener and I ain't no quiter! ( what's the options once you tear it apart?)
Keep on keepin' on Dudes.
Old Apr 13, 2012 | 06:53 AM
HlhnEast's Avatar
HlhnEast
Congrats, sounds like a ton of work. What type of carpet spray did you use and did it make the fibers clump or turn hard? I want to do my red carpets that have sun faded badly.
Old Apr 13, 2012 | 08:21 AM
Keystring's Avatar
Keystring
Before and after pictures works too..
Or even just 'after'...
Old Apr 13, 2012 | 08:53 AM
cv67's Avatar
cv67
St. Jude Donor '05
Welcome to the "I actually did it and know the stuff dont work" club.
Least you got everything tighetened down right. Bet you have less squeaks and rattles.
Old Apr 13, 2012 | 10:01 AM
ejscarfo's Avatar
ejscarfo
I have the Mid-America dye in the spray cans and I'm looking to do my carpets as well. It works great on the vinyl and plastic pieces. Just a little leary about painting carpet.
Old Apr 13, 2012 | 07:34 PM
blr33439's Avatar
blr33439
If you really want to make a sound level difference, go with dynomat extreme. I used it on a 98 Nissan Frontier and it made a huge difference. If you don't care about the added weight and cost, go with two layers. It is an aluminum backed tar roll that peels and sticks. Its not the lightest, but most lightweight sound deadeners are just gimmicks. When I get the time, I am putting at least one layer down in my 90. You can also finess a layer onto the back of the door panels for even more quieting. Getting it on the firewall will be the real challenge.
Old Apr 13, 2012 | 08:04 PM
mrmtrtrnd's Avatar
mrmtrtrnd
I used the same type mat in my truck and had the same results.
Old Apr 13, 2012 | 09:35 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Use the "RIT" fabric die that is made for coloring clothes. Put it in a spray bottle and have at it. It's sold all over and it doesn't dry hard.
Old Apr 14, 2012 | 08:33 AM
HlhnEast's Avatar
HlhnEast
Thanks Johnnie. I am definitely considering the RIT as well. Didnt know if the Phat man had found a good spray product. RIT may be the only real option to keep the carpets soft.
Old Apr 14, 2012 | 02:59 PM
Hotred94's Avatar
Hotred94
I put down two layers of Home Depot foiled thermo layer to help the noise and the heat coming through the floor board. Didn't help much with the noise but it did help with the heat. The most noticeable thing I did for noise was to put in a headliner in the glass roof panel. That helped with sun heat too.
Old Apr 14, 2012 | 03:06 PM
illenema's Avatar
illenema
Sounds like so work, its rewarding venture.
I purchased a 95 very that was in a texas flood. Sight unseen which i regretted. but its pretty much done now except the insulation/carpet.
I have 1 up on you as i had to use a high speed steel wheel and about 1 hr of grinding to get all the old paint/sealer off.
Resealed/painted the floor ect- was waiting to get the new insulation
Old Apr 15, 2012 | 10:42 AM
blr33439's Avatar
blr33439
Put down a layer of dynomat extreme or similar product while the carpet is out. It will be one of the best upgrades you will ever do. I am considering raising dynomat up on my project to do list.
To Finished!!!!!
