mercury switch
Old Apr 15, 2012 | 05:58 PM
ps374's Avatar
ps374
Default mercury switch
I am not sure I am using the right wording but when you open the hood on early C4s the courtsey lights go on under the hood. The bulb has in front of it what looks like a end to a bulb with no glass. I think that is what turns the courtsey light on under the hood. Are those little switches sold in auto parts stores or must they be order special from Corvette suppliers. I believe one of mine is bad as the bulb flickers until you keep playing with the hood.
Old Apr 15, 2012 | 06:26 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Could be a flakey filiment in the bulb; replace the bulb or swap side to side to check it out.
Old Apr 15, 2012 | 07:06 PM
PAINTER MAN's Avatar
PAINTER MAN
The last mercury switch I replaced, I got from Corvette Central. I tried the local parts houses unsuccessfully.
Hard to find item made with mercury anymore.
Old Apr 15, 2012 | 07:47 PM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Or a bad connection in the socket itself, the mercury switches rarely fail.
Old Apr 16, 2012 | 08:14 AM
HlhnEast's Avatar
HlhnEast
About the only way for them to fail is the mercury to leak out. They are just a dab of mercury with two contactors in a glass bulb.
To mercury switch
