Temp sender / alternate wiring question
No temp reading from the gauge on the engine. Oil reads normal. I believe the main radiator cooling fan is not coming on due to lack of signal from the CPU telling it that it's time. I am not familiar with American cars (sorry, mostly air cooled German convert to American stuff) so, is the water temp sender on the radiator or the block? If block, is it the lower end on the passenger side? I saw some kind of sending unit lacking a wired connection while I was changing the oil.
If I cannot get the main fan to function, what is the best way to rig the fan? toggle switch direct to battery? Should I use a relay to trip the juice to the fan motor? Is that relay next to the radiator on the drivers side the fan relay or is it the relay fwd of the battery?
I figured out it wasn't working when I got stuck in traffic last week and the oil temp got pretty toasty. I bought the car at the start of winter and had no issues while it was pretty cool outside.
Thanks fellas for input and experience!
If engine is running correctly , the coolant temp sender (CTS ) for the computer ( at front of intake manifold ) is working and sending correct temp indication to the computer (ECM )
If it wasn't you would have engine operation problems
Faulty temp gauge is a different problem with the gauge / wiring / gauge sender between # 6 and 8 plugs
Most likely your problem is with the fan or wiring to it ; hotwire the fan and confirm fan motor works.
Then check for permanent 12V ( thick red or org ) at the relay , fusible link supplying relay may be blown
Bypass the relay and see if fan runs ; confirms wiring from batt to fan intact
Check fan fuse ( control side of relay ) check for 12V ; key on on thin ( blue ? ) wire @ relay
Ground the relay control wire ( green ? ) and see if the relay closes to run fan ; relay may be faulty
or use a standalone fan sending unit ( no switch required )
http://www.racerpartswholesale.com/p...n_Accessories2
like this of the working range you require
The relay for the fan is mounted on the wheelwell below the master cylinder.
Here's a diagram of what the ALDL connector looks like:
When I unplug the relay by the battery to check the function of the hot wire, I got 12v hot.
Question is: If I jumper the fat red hot wire with the relay unplugged to the fat black ground in the relay connection, should that kick on the fan? If so, it didn't.
Thanks again.
Thanks for the reply CC.
Disconnect the plug out of fan motor and put 12V ( + ground ) there to see if fan actually works
Not exactly recommended to put the 3A relay control supply direct to the fan that draws 20A +
Nada.
So, First things first. A buddy happens to have a fan from his parts car so, I am going to pick that up tomorrow after work.
I picked up a temperature sender which is not in yet. The dash gauge just reads "LO" and never shows a temp so, I am pretty sure I need to sort that as well.
Are the bulbs in the information control center easily replaceable and available at any chain store? I would like to jump the harness to get the codes but, the check engine light is out.
I paid my dough to go play with the Granbury Texas Vette Club at Texas Motorsports Ranch in two weeks so, I am on a tear to get my car where I think she needs to be to do that.
Thanks again for you help!
Stu
ps. No Worries SunCr.
The tapping wasn't to make a solid connection... it was just to listen for anything and check for current. The wire should only melt with current flowing enough to heat up the wire and that would take a solid connection. When I say tap tap it's like accidentally hitting ground with a hot wire. I'm sure we have all done that with no permanent damage except for a quick reaction to remove the offending touching!
Thanks for the concern!
