lowering a c4
Old Apr 23, 2012 | 08:26 PM
onDjuice's Avatar
onDjuice
Default lowering a c4
Need some help on how low i can go.
I,ve lowered my car but i would like to go about 1/2" more in the front. I,ve cut the rubber ends and trimed the center blocks. What can i do to get that 1/2" more???
Old Apr 23, 2012 | 08:37 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Is this the stock monospring? Are you using the lowering kit?
If it is the stock monospring I'd say that about all you can lower it. Did you remove the shims?
This is my 95 with Sports Monospring without shims. Using this set up, this is the lower it goes.
Stock Vs Sport
Old Apr 23, 2012 | 08:50 PM
onDjuice's Avatar
onDjuice
My car is has the z07 package. The monosprings are stock in my car. And i was thinking of playing with a camber adjustments.
Old Apr 23, 2012 | 09:12 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Camber adjustment will NOT lower your front end.
Old Apr 23, 2012 | 09:46 PM
StealthLT4's Avatar
StealthLT4
If you've cut the rubber end-cushions off, cut off the rubber mounts on the topside of the spring (near the middle) and removed all aluminum spacers from on top of the spring, that's all you can do. There are aftermarket alternatives from an adjustable spring to coilovers.
Old Apr 23, 2012 | 10:03 PM
onDjuice's Avatar
onDjuice
If i pull some shims out and get some more negative camber 1 or 2 degrees it will low the car alittle..
Old Apr 25, 2012 | 01:47 AM
Rag Top's Avatar
Rag Top
Old Apr 25, 2012 | 03:10 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
And impact the tire wear A LOT! Not worth the 1/2"
You'll carve off the inside of the tires before the tittys on the outside scrub off!
Do yourself a big favor and find a different size tire.
Oh by the way, did you remember to cut down the front bump stops?
Old Apr 25, 2012 | 08:22 AM
onDjuice's Avatar
onDjuice
Thanks bro i will poke a hole pull those bump stops out.
Has for the camber not lowering the ride height.It will has you pull shims out you are leaning the tire in at the top which lows so what.
Old Apr 26, 2012 | 12:10 PM
JrRifleCoach
Another thought:
Rather than adjusting camber, why not drop your tire pressure?
Old Apr 26, 2012 | 12:20 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Another thought:
Old Apr 26, 2012 | 12:41 PM
alexmurphy's Avatar
alexmurphy
See, I had this problem too. I filled up my trunk with sand bags and taped some 45 pound weights to the underside of my hood
Like a boss
Old Apr 30, 2012 | 09:48 PM
onDjuice's Avatar
onDjuice
I took out the front spring and i have a thin spacer above the spring were they are bolt to the frame.
Can i lose that too???
Old May 1, 2012 | 12:44 AM
JrRifleCoach
What is the spacer thinkness? Like and eighth inch? That could translate to about an 1/8" more drop.
Sure go for it! But you'd be better served by pulling those shims and cranking in a coupla degrees of negative camber.
DooD!
Old May 1, 2012 | 02:05 AM
Z51JEFF's Avatar
Z51JEFF
How much money do you have to spend on this?VB&P sells an adjustable spring that will allow you to put that car on the ground.The front spring is about $500.
Old May 1, 2012 | 08:16 AM
onDjuice's Avatar
onDjuice
DooD!
Thanks bro!!
Old May 1, 2012 | 09:31 PM
Z51JEFF's Avatar
Z51JEFF
You need something between the spring-frame.With no insulation the spring with squeak.
To lowering a c4
